Old 08-20-2019, 11:54 PM   #1
Slim240
Slim240 is an unknown quantity at this point
KA KA24E No Spark
I installed a new ignition coil, new starter, and a new timed-correctly distributor but my 240 does not get any spark to the plugs. I made sure the spark plugs still worked, the distributor is getting 12v, the ignition coil is sending out 12v, the distributor cap is also taking in those 12v from the starter but for some reason im getting no spark to the plugs. Any ideas?
Last edited by Slim240; 08-21-2019 at 12:09 AM.. Reason: ignition coil is sending 12v*
Slim240 is offline   Reply With Quote
Old 08-21-2019, 12:18 AM   #2
Slim240
Ive been reading around for a little bit and it may have something to do with the ignition control module but i dont want to spend an extra $80 right now, any way to test the module out?
Old 08-21-2019, 08:41 AM   #3
crash n' burn
crash n' burn's Avatar
crash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura about
Had an issue exactly like this. I was getting power to everything, replaced every ignition component (plugs, wires, dizzy cap, rotor, then dizzy itself, coil, ICM) with known working ones.
Ended up being a bad ECU.
Key'd Performance
@chelsea.thiccnofa
crash n' burn is offline   Reply With Quote
Old 08-27-2019, 06:32 PM   #4
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Blown ecu or short in engine harness
kennedy8383 is offline   Reply With Quote
Old 08-28-2019, 09:09 PM   #5
Slim240
Hopefully that’s case even though a buddy of mine tested out all the pinouts but he’s bringing a spare single fame ECU Friday and and I’m praying that’s the problem And the short seems slightly unlikely but that’ll be my last resort before a swap once I’ve got the money
Old 08-31-2019, 07:16 AM   #6
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Did you also test for fuel? no spark or fuel = no signal from CAS to ECU. If you in fact aren't getting both, I'd start with a continuity check from the CAS wiring to ECU, should be a single wire and a ground I believe. Heading out soon or I'd pull the FSM and find them for you.
NukeKS14 is offline   Reply With Quote
