Old 08-13-2019, 10:48 PM   #1111
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Good news is the leak was coming from one of the oil lines. All fixed up. Boost leaks located and all set. Warmed it up a few times, etc. So far so good.
RalliartRsX is offline   Reply With Quote
Old 08-13-2019, 10:50 PM   #1112
S13VE
S13VE is an unknown quantity at this point
Excellent news.
Good luck next week/week after.
S13VE is offline   Reply With Quote
Old 08-14-2019, 10:52 AM   #1113
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
Can anybody with an s13 measure the distance from their head to the strut tower on the intake manifold side for me? Fabricator wants to know for plenum clearance and I don’t have an engine in the car quite yet. Would be a huge help!
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 08-14-2019, 11:03 AM   #1114
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
shut up and buy my mazworx manifold
https://zilvia.net/f/showthread.php?t=668441
Old 08-14-2019, 11:11 AM   #1115
d9m13n
d9m13n's Avatar
slap a tape measure across that bad boy and let me know what you got
TBH I would have just bought a plazmaman manifold if I knew this guy was going to take 8 months to put this manifold together, but Ive already invested the money and need to see it through
Old 08-14-2019, 11:31 AM   #1116
RalliartRsX
Trader Rating: (32)
Same guy who did JP's mani??
PM me on who you went with for your block.
Old 08-14-2019, 11:36 AM   #1117
d9m13n
d9m13n's Avatar
Yep, Kyle Nardi. Kid does good work, just really hard to actually get him to do the work. Heard that from a lot of people, not just my experience. Doesnt help that hes had a lot of personal struggles throughout the last year or so but thats neither here nor there.
Old 08-14-2019, 11:39 AM   #1118
brndck
brndck's Avatar
no prob, ill measure it this evening
Old 09-05-2019, 07:41 AM   #1119
d9m13n
d9m13n's Avatar
What has everyone done for their catch can/PCV routing? p12 valve cover
Finally have an engine in my car and Im excited to start getting into the little details
Old 09-05-2019, 08:11 AM   #1120
RalliartRsX
Trader Rating: (32)
Run the PCV port and back port to catch can. Keep the block ventilation. Run catch can to either a vacuum source (turbo inlet) or open.
Done.
Old 09-05-2019, 08:12 AM   #1121
d9m13n
d9m13n's Avatar
Block ventilation meaning back right hose connection on the block to the back right fitting on valve cover?
Old 09-05-2019, 08:22 AM   #1122
RalliartRsX
Trader Rating: (32)
Yep. The one on the driver's side by the firewall/exhaust/downpipe. Keep that line in place. Vent the rest of the valve cover to whatever you see fit.
Old 09-05-2019, 08:31 AM   #1123
d9m13n
d9m13n's Avatar
Thanks! Easy enough. Are most people keeping the stock pcv valve or just replacing with a straight fitting?
Old 09-05-2019, 08:46 AM   #1124
RalliartRsX
Trader Rating: (32)
Replacing with a straight fitting. Keep the PCV if routing to the intake (manifold). The only reason the PCV is there is to not allow boost back into valve cover causing all sorts of issues (like increased crankcase and under valve cover pressure for instance) and to allow only vacuum to work on help pulling the crank case pressure and oil vapor and allow the baffles in the valve cover to take care of it.
Old 09-05-2019, 07:55 PM   #1125
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
Now that you mentioned straight fitting, what kind of fitting exactly. Tap the valve cover for an AN screw on fitting? I'm wondering if there is another type of fitting that'll work that does not involve removing my valve cover. lol
kojiki88 is offline   Reply With Quote
Old 09-06-2019, 11:37 AM   #1126
brndck
brndck's Avatar
taarks makes a block off fitting. you could always take something like this and drill/tap it for whatever breather line you like, rather than remove your valve cover for welding
https://www.efisolutions.com.au/pcv-...12-r33-r34-r35
Old 09-06-2019, 01:28 PM   #1127
d9m13n
d9m13n's Avatar
The Sr20/Sr22vet thread
P12 VC pcv fittings are screw in if I’m not mistaken, but I’m not sure what the threads are. I’ll try to find out if nobody knows offhand. Would make it much much easier to get an adapter rather than welding/pressing/tapping etc.
Edit: I’m only referring to the pcv fitting being screw in. The regular hose end fittings on the right side and rear of the VC are press fit
Old 09-08-2019, 03:09 PM   #1128
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
^ No they aren’t. They use a plastic PCV valve that’s a press fit with a rubber grommet like an s14 / s14 vc.
mewantkouki is offline   Reply With Quote
Old 09-08-2019, 03:12 PM   #1129
d9m13n
d9m13n's Avatar
You’re right. I saw p12 pcv valves with threads after a quick search, not realizing they’re for p12s with the qr20 not the sr.
Old 09-09-2019, 12:13 PM   #1130
PRT73
PRT73 is an unknown quantity at this point
Hello everyone, your page makes me dream, I am thinking to buy head sr20ve, I currently have a sr20det redtop, with head hs, because of a pusher, the head sr20ve on a sr20det and reliable ? I see video or shims jumps ? because my goal and 550whp for drift , max 8000rpm ( stock springs ?)
thank you for the support!
PRT73 is offline   Reply With Quote
Old 09-09-2019, 12:58 PM   #1131
brndck
brndck's Avatar
there are a number of people who do have issues with shims spitting out. some people are machining custom valve stem caps to resolve the issue, other people are using shimless valves to solve the issue.
VE head does have many advantages over normal sr20 head, but it is NOT cheap.
Old 09-09-2019, 01:05 PM   #1132
PRT73
Thank you for the answer !!! Interressing as a solution, do you have any links as I look at the machined shims?
Old 09-09-2019, 01:20 PM   #1133
brndck
brndck's Avatar
I don't have any links, one of the local machinists around here is working on producing them, but he's not a large business or anything. I'll try to get some photos if I can.
Old 09-09-2019, 01:24 PM   #1134
PRT73
Thank you because here in France no information I would be the only one
Old 09-09-2019, 02:43 PM   #1135
brndck
brndck's Avatar
you may want to contact BS Bildeler, I believe they're in Norway or Sweden? they built a crazy sr20vet a few years ago
https://www.youtube.com/watch?v=co0vuzqEpS0&fs=1" width="644" height="390">https://www.youtube.com/watch?v=co0vuzqEpS0&fs=1" />https://www.youtube.com/watch?v=co0vuzqEpS0">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=co0vuzqEpS0
Old 09-09-2019, 09:56 PM   #1136
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
I'm running custom valves, the top of the valve stems are machined. the valves are just longer, tips are longer then machined to OE spec clearances. so in term the shims are tossed out.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 09-10-2019, 09:35 AM   #1137
PRT73
great , and looking mazworx
Old 09-10-2019, 09:36 AM   #1138
PRT73
interresed , you have picture ? and the price for the setup ? thanks you
Old 09-10-2019, 12:02 PM   #1139
brndck
brndck's Avatar
https://www.mazworx.com/store/p/558-...ves-clone.aspx
your machine shop has to do all the measuring and machining to set the proper lash for your head. the big issue is, if you machine too much off, you have to replace the valve, you can't really add length back on to it.
Old 09-10-2019, 12:29 PM   #1140
d9m13n
d9m13n's Avatar
If there's anybody whos been lurking this thread and wanted to start building an sr20vet, all the parts from my old setup are now for sale and Ill make a killer package deal if someone wants to take everything Stout 500whp shortblock that just needs machining and assembly!
