Old 10-13-2019, 04:35 PM   #1
boost86
boost86's Avatar
boost86 is an unknown quantity at this point
Power FC -- S13 SR20DET
S13 SR20DET Power FC, Model # SR2017
$450
This is intended for a 96-98 S13 SR (J4/J5)
For owners of redtops and early blacktops, you can do a re-pin of your harness at the ecu. The only difference, according to the below diagrams, is the coil packs pinout locations.
62/E5 ECU Pinouts (Red Top SR20DET): https://drive.google.com/file/d/0B9F...lQb2RnOTA/view
J4/J5 ECU Pinouts (Late 180sx SR20DET): https://drive.google.com/file/d/0B9F...lQb2RnOTA/view
boost86 is offline   Reply With Quote
Old 11-06-2019, 04:08 AM   #2
boost86
boost86's Avatar
bump msglength
Old 11-06-2019, 10:21 AM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
no commander?
Old 11-06-2019, 10:29 AM   #4
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
What he said ^
Dboyizmlg is offline   Reply With Quote
Old 11-06-2019, 05:06 PM   #5
boost86
boost86's Avatar
I have a commander in my car but I'll charge an extra $50 for it.
Old 11-06-2019, 07:06 PM   #6
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
So after the re-pin I can run this on a red top no problem? Something about o2 sensors? Also if I have a commander for a rb power fc, are all commanders identical?
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 11-07-2019, 09:01 AM   #7
brndck
brndck's Avatar
unfortunately, commanders are NOT universal
commander must match the ecu.
Old 11-08-2019, 06:40 PM   #8
boost86
boost86's Avatar
Some commanders work for more FC's than others. I tested the commander with this PFC once and it worked. The commander # is FCC3. I will double check to verify compatibility between ecu and commander.
Old 11-08-2019, 06:42 PM   #9
S14rebuild
Redtop or blackntop s13 power fc can be used either or, just repin the harness (02 sensor wires) n use correct 02 sensor..skinny or fat
Thats all
Old 11-08-2019, 06:55 PM   #10
boost86
boost86's Avatar
FOR REFERENCE:
62/E5 Wiring (Early SR20DET): https://drive.google.com/file/d/0B9F...lQb2RnOTA/view
J4/J5 Wiring (Late SR20DET): https://drive.google.com/file/d/0B9F...lQb2RnOTA/view
These PDF's are courtesy of Wiring Specialties-- so we can thank them for making some legible pinout diagrams.
According to these two diagrams, the ignition pin locations are the main difference between E5/62 and J4. It appears the oxygen sensor remains in the same pin on both ecu's.
Old 11-11-2019, 03:33 AM   #11
boost86
boost86's Avatar
take it to the top
Old 11-16-2019, 09:25 AM   #12
boost86
boost86's Avatar
Bump for updated post. See above regarding differences between e5 and j4 ecu's.
Old 11-24-2019, 05:03 PM   #13
boost86
boost86's Avatar
ttt --- msg length
Old 12-03-2019, 08:14 PM   #14
nolandavid
nolandavid's Avatar
nolandavid is an unknown quantity at this point
Send a message via Yahoo to nolandavid
bump not a bad price.
nolandavid is offline   Reply With Quote
Old 01-13-2020, 04:58 PM   #15
boost86
boost86's Avatar
someone here needs a power fc for a late sr20det
Old 01-19-2020, 08:43 PM   #16
boost86
boost86's Avatar
ttttttttttttttttttttttttttttttttttttttttttttttttt
Old 01-28-2020, 03:48 PM   #17
boost86
boost86's Avatar
to the top -- msglength
Old 01-29-2020, 08:12 PM   #18
boost86
boost86's Avatar
Edit: Sold
