Old 11-18-2019, 01:30 PM   #1
findmea240
findmea240 is an unknown quantity at this point
1.5JZ S14 Poject *Big Price Drop*
Hello zilvia
I am re posting this ad because I am getting an error page for some reason if I try to edit my previous posting.
I lowered the price significantly to speed the sale and to match the work needed to be done. I am not interested in parting out and while I am looking for a straight sale Id be open to a trade offer if you had something in mind.
ONTO THE CAR
I had the machine work done by Chuck Exton from Exton Automotive Machine Shop in PA. Chuck had made a name for himself in the drag scene in the funny car world and I have seen many successful local builds come out of his shop as well.
I got the car running and before I got the chance to put it on the dyno, decided I wanted to get into drifting so I took the car back apart and began the roll cage where the project stopped. The cage is almost complete just needs a rear cross bar and gusseting if preferred.
The car is apart but everything is in a bin or bag so a uhaul & car trailer or big truck bed & car trailer will be the necessary method of transportation.
This car comes with full clean interior!
Located in Oxnard CA
Ok now for the fun stuff. Im going to list the parts and their retail price to get an idea where the current price point is coming from.
Parts list comes in around $21k not including the chassis itself, the machine work and also a few other things I know im forgetting.
ASKING $9,500 FIRM
DRIVETRAIN - $12,500
ENGINE $5755-1.5JZ (1JZ non vvti head on a 2JZ block)
HEAD
BC 264 Camshafts - $740
BC Springs and Titanium Retainers - $415
SupraStore Cam Gears - $200
New OEM Valve Seals
BLOCK
CP 10.5:1 Pistons With Upgraded 9310 Wrist Pins -$1000
Carillo H-Beam Rods With Upgraded SPS CARR Bolts $2100
Titan Motorsports Billet Main Caps - $590
ATI Super Damper - $390
A.R.P. Head and Main studs- $320
Transmission $3800
R154 Transmission With All Marlin Crawler Upgrades - $2000
SPEC Twin Disk Clutch W/ Wilwood Master Cyl - $1800
TURBO KIT $2945
Precision 7275 Turbo - $1600
Tial 50mm BOV - $230
Tial MVS 38mm Wastegate - $265
4" V-Band Downpipe to 3" V-band Exhaust
CXRacing manifold - $500
Large Core Intercooler & Piping - +/- $350
Chassis $8795
FUEL $1990
ID2000cc Injectors- $1400
Radium Engineering Surge Tank W/Dual Bosch 044 Pumps - $440
Walbro 400LPH E85 In-Tank Pump - $100
Ebay Top Feed Fuel Rail - +/- $50
ELECTRONICS $3380
Upgraded 240Amp Alternator - $400
AEM V2 Standalone - $1000
Chase Bays Harness *unused* - $1200
3.5 Bar Map Sensor - $150
AEM UEGO Wideband $130
Oil Pressure & Boost Gauge - $100
Dakota Digital Tach Adapter - $80
Dakota Digital Speedo Adapter - $80
LS Coil Packs - $240
Suspension $3425
ER Spec Roll Cage - $500
ISR PRO Arms - $600
Solid Diff & Subframe Mounts - $205
Q45 Diff + J30 Axles - +/- $200
Square 17x9.5 Wheels W/ Nitto NT05 on rear - $600
CXRacing 2jz Swap mounts - $440
Maverick Dual Z32 Caliper Mount - $230
Z32 Front and 4 Z32 Rear Calipers - $600
ISR Hydro Ebrake - $50
https://ibb.co/xCgmTrT
https://ibb.co/W50ZW8r
https://ibb.co/sb3W1r9
https://ibb.co/qydtgmQ
https://ibb.co/JQRt8mB
https://ibb.co/7WxxBdx
https://ibb.co/tskpSLP
https://ibb.co/Sv3XPV3
https://ibb.co/QvBwdxX
https://ibb.co/NF75wHb
https://ibb.co/NNNytPd
BEFORE CHASSIS FAB
https://ibb.co/pP2HP9g
https://ibb.co/SRFKj6v
findmea240 is offline   Reply With Quote
Old 11-18-2019, 07:45 PM   #2
Whitey13
Whitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enough
Where is it located?
Whitey13 is offline   Reply With Quote
Old 11-18-2019, 07:54 PM   #3
findmea240
Car is located in Oxnard, CA
Thank you I updated the posting with the info
Old 01-07-2020, 02:18 PM   #4
Turbostrong2
Turbostrong2 is an unknown quantity at this point
Bump!!!!!!
Turbostrong2 is offline   Reply With Quote
Old 01-08-2020, 09:16 AM   #5
NY2NV Miner
NY2NV Miner is an unknown quantity at this point
Pictures aren't working for me. I don't know if anyone else is having this issue.
Road Racing FTW
NY2NV Miner is offline   Reply With Quote
Old 01-16-2020, 07:09 PM   #6
allforthebenefit
allforthebenefit is an unknown quantity at this point
Wish you were closer!
allforthebenefit is offline   Reply With Quote
