Old 07-18-2019, 08:30 AM   #1
GRNxS14
GRNxS14 is an unknown quantity at this point
RB RB Parts - Tons of stuff, OEM & aftermarket
All prices are shipped within the continental U.S.! No waiting for shipping quotes, and typically I can ship anything next day through my work. PM me or for the quickest response text me at 513-869-0556 any time
RB25/26 starters - $40 - used - known good OEM Nissan unit (Top is available, bottom one pictured is sold)
RB26 Alternator tensioner bracket - $20
RB26 Valve spring compressor - $120 - New - I make these, it's the only one of its kind as far as I know and works extremely well. Bolts to the cam cap holes and allows you to disassemble valve springs either on a bench or on an assembled engine with a pressurized cylinder. All steel construction
RB26 cam sensor brackets x2- $20 each
RB oil caps - $15 - used - One OEM, one Ebay style
RB26 rear water port fitting - $15 - used
RB26 turbo return line fitting - $15 - used - part that threads into the block for the front turbo oil drain
Universal 6an fuel/power steering cooler - $20
RB26 coil packs (individual) - $15 each - used - missing stalks but good otherwise
RB26 coil pack set with harness - $50 - used - known good set, includes good sub harness and bracket
RB26 balance tube - $20 - used
RB26 oil filter housing - $25 - used
RB26 seal driver set - $40 - new - Seal drivers for the front main, rear main, and cam seals. Very solid 3d printed construction, holds the center spring in place and allows you to tap the seals in with a hammer without worrying about damaging them.
RB26 water necks - $15 each - used - bottom one has an additional port added, top now has the small outlet welded shut for single turbo use
RB OEM water pump pulley - $15 - used
RB26 S14 Kouki
GRNxS14 is offline   Reply With Quote
Old 07-20-2019, 02:17 PM   #2
GRNxS14
Weekend bump! A good amount of stuff sold already!
RB26 S14 Kouki
Old 07-30-2019, 01:51 PM   #3
GRNxS14
BUMP! Removed all of the stuff that's sold already, and adjusted some prices. I'd love to have some more stuff go!
RB26 S14 Kouki
Old 08-06-2019, 07:48 AM   #4
GRNxS14
Buuuuuuuuuuuuuuuuuuuuuuuuuump
RB26 S14 Kouki
Old 08-12-2019, 10:37 AM   #5
GRNxS14
Bump, everything still listed is available
RB26 S14 Kouki
Old 08-25-2019, 09:01 AM   #6
GRNxS14
Ttttttttttttttttttttttttt
RB26 S14 Kouki
Old 09-16-2019, 03:35 PM   #7
GRNxS14
Bump! All parts that have been sold already have been removed from the thread. Everything left is still available
RB26 S14 Kouki
Old 10-09-2019, 10:07 AM   #8
GRNxS14
tttttttttttttttttttttttttt
RB26 S14 Kouki
Old 12-12-2019, 01:23 PM   #9
GRNxS14
Bump, lowered prices, if it hasn't been deleted from the thread, it's still available!
RB26 S14 Kouki
Old 12-13-2019, 07:57 PM   #10
street240sx
street240sx's Avatar
Trader Rating: (22)
street240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enough
Feedback Score: 22 reviews
I want the mmr oil filter thing
street240sx is offline   Reply With Quote
Old 12-16-2019, 08:34 AM   #11
GRNxS14
PM replied
RB26 S14 Kouki
Old 12-20-2019, 12:24 PM   #12
Mr.slipngrip
Mr.slipngrip is an unknown quantity at this point
I'll take the valve cover fittings
Mr.slipngrip is offline   Reply With Quote
Old 12-25-2019, 12:29 AM   #13
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
Rb26 starter fit on rb25?
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 12-27-2019, 07:32 PM   #14
GRNxS14
Yes, I was using this on an RB25 trans and rb25 flywheel on my 26
RB26 S14 Kouki
gtr, rb20, rb25, rb26, skyline
