Old 01-20-2005, 08:20 PM   #1
nocturnaldrifter
nocturnaldrifter's Avatar
nocturnaldrifter is an unknown quantity at this point
Send a message via AIM to nocturnaldrifter
Help with LSD!!!
I just got a Nismo 2-way LSD (part #3842ORS430). I have the LSD and that is it. Will this fit into my 92 240sx without new sideshafts? If so how hard is the install? Any feedback is much appreciated.
nocturnaldrifter is offline   Reply With Quote
Old 01-20-2005, 08:28 PM   #2
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
did you get the model that is for an open differential or one for a car with a vlsd? the shafts i believe are different lengths between the two models. if you got the right model then it should fit in with no complications.
l33tmonkeyman is offline   Reply With Quote
Old 01-20-2005, 08:40 PM   #3
180sxdrifter
180sxdrifter's Avatar
180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light180sxdrifter is a glorious beacon of light
you didnt get the kit?
its 38420-RS661 for open diff
comes with new seals, new bearings, new cover gasket, and 1.5L of 80W90 Nismo LSD Oil
...and it doesnt require new sideshafts
Instagram @ikigai.no.jinsei
180sxdrifter is offline   Reply With Quote
Old 01-20-2005, 08:48 PM   #4
sideviewcivic
sideviewcivic has a little shameless behavior in the past
Send a message via AIM to sideviewcivic
In case of difficulty understanding on how to install an LSD. see about getting last month's HCI mag, since it covers a very indepth article on dropping a KAAZ lsd in. Don't worry about the differences b/w the kaaz and the nismo lsd. install is the same for both. break-in procedure is the only difference.
-Aaron
sideviewcivic is offline   Reply With Quote
Old 01-20-2005, 08:52 PM   #5
nocturnaldrifter
Yeah that's the problem it's from Japan so I don't know if it is for the VLSD model or for the Open diff model...and I didnt get the kit...I just have the actual LSD and the part number.
Old 01-20-2005, 09:11 PM   #6
180sxdrifter
-Aaron
actually KAAZ's break-in procedure is recommended with all LSD installs, supposedly the Nismo is a drop-in (no break in necessary) but I played it safe since its a special mod
2way LSD
Old 01-20-2005, 09:23 PM   #7
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
how much are these nismo lsd's running ya?
and how much is that kit?
I've been seeing them on Ebay, and i've also noticed them at private vendors, but never really looked into them until recently...
i wonder if my local nissan dealership would stock them?
anyways.. sorry not meaning to highjack this thread.
CoasTek240 is offline   Reply With Quote
Old 01-20-2005, 09:38 PM   #8
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
It could be for the vlsd model or the open diff model, same thing. The difference is the length of the driveshaft of the ABS model cars, not the differential difference.
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 01-20-2005, 10:10 PM   #9
nocturnaldrifter
so it just depends on if the LSD is for ABS or not?
Old 01-20-2005, 11:32 PM   #10
180sxdrifter
you kno ABS and VLSD come in a package most often with HICAS also
Old 01-20-2005, 11:42 PM   #11
s13irdie2
s13irdie2 is on a distinguished road
i just put in my kaaz lsd and the install was really easy. theres a thread on the kaaz install and i followed it, and mine worked perfect. just make sure to torque the bolts right especially the ones inside the differential. set the backlash back to stock and youll be fine. if you dont trust yourself, at least take it apart and send the pumpkin to a shop and let them do it. taking it off is super simple. hope this helps.
1990 s13
IslandMotorsports, Inc.
s13irdie2 is offline   Reply With Quote
Old 01-21-2005, 08:15 AM   #12
Biggamehit
Biggamehit's Avatar
Biggamehit will become famous soon enoughBiggamehit will become famous soon enoughBiggamehit will become famous soon enough
Send a message via AIM to Biggamehit Send a message via MSN to Biggamehit Send a message via Yahoo to Biggamehit
that sounds good. i was about to buy that kit but ran out of money so im trying to find a diff from a j30 ( 95 96 )
Facebook: Pink Ranger Drift
Biggamehit is offline   Reply With Quote
Old 01-21-2005, 11:49 AM   #13
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
Nocturnal, I believe there are two different Nismo LSD's. When I got mine there were 2 or 3 different part numbers on the manual. I can check when I get home if you have the right one.
I believe there is one where you DO need new sideshafts. That would suck.
PM or email me to remind me to look.
I got mine of off Ebay ridiculously cheap. It was brand new. So check there. I can't imagine ever going back to an open diff. LSD's are soooo much fun.
JaeTea is offline   Reply With Quote
Old 01-21-2005, 03:05 PM   #14
sideviewcivic
I have the nismo manual::here are tolerances and instructions:: M12 bolt (98-112 ft-lbs), M13 (130-145 ft-lbs), Bearing cap (65-72 ft-lbs, use threadlocker!!!), standard backlash(normal pitch .13-.18mm, fine pitch .10-.15mm), Rear gear case bolts (1-2 ft-lbs)::: also to note other than RS-500A is states to not use side flanges that came with the car.
