Old 04-27-2020, 10:29 AM   #1
blacksr
blacksr will become famous soon enoughblacksr will become famous soon enoughblacksr will become famous soon enough
WTB RHD Brake Master Cylinder
need a 1"+ brake master cylinder for right hand drive car (S13). 3-port. please PM with pics and price.
blacksr is offline   Reply With Quote
Old 04-27-2020, 12:31 PM   #2
TheRealSy90
TheRealSy90's Avatar
You can order a 1" brake master from a 94 D21 Pickup, 4WD model. It's a 3-port 1" bore, same left side ports as a RHD brake master.
https://www.rockauto.com/en/catalog/...+cylinder,1836
https://www.rockauto.com/en/moreinfo...=2378&jsn=2378
https://www.rockauto.com/en/moreinfo...=2387&jsn=2387
Such a good signature.
Old 04-27-2020, 05:04 PM   #3
blacksr
thanks very much for that!
Old 04-27-2020, 05:08 PM   #4
blacksr
oh, but this isn't going to fit my lines. there is barely any clearance on the other side.
Old 04-28-2020, 12:03 PM   #5
TheRealSy90
How so? If your car already has a RHD brake master the ports on these are the exact same location.
If you're converting to a RHD brake master on a LHD car to move the brake lines away from the turbo/manifold, the stock lines can be Carefully re-bent to work.
Or you can use aftermarket brake lines that use Banjo fittings like what GKTech and ChaseBays offer. I have done this with both methods multiple times.
Old 04-28-2020, 02:56 PM   #6
blacksr
ah, you're right!
Old 05-01-2020, 08:38 AM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
I ordered lines from suspicious garage.
check with them and see if they offer something for rhd.
I dunno if the lengths would need to be different
https://suspiciousgarage.com/product...relocation-kit
Old 06-08-2020, 12:03 PM   #8
economix
economix's Avatar
economix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud of
I'm gonna ask a really dumb question but these three (3) BMCs suggested all work with a RHD S13? Only asking because I'm going to my mechanic to get my 180SX (2 weeks old for me, 1995) up on a lift and have a USDM 300ZX (Gent5) BMC which would have me putting holes in my strut tower to run the lines, which I'm totally not cool with. But for $60, man, these prices are almost too good to be true! I'm just here second guessing things before pulling the trigger.
89 240SX w S14 SR20; 95 JDM 180SX S13 SR20; 09 Acura TL SH; 18 Jaguar XE S
economix is offline   Reply With Quote
Old 06-08-2020, 12:05 PM   #9
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Not sure how off the S14 one is but I have a used oem s14 Kouki BMC off my clip I didn’t use.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 06-08-2020, 02:26 PM   #10
TheRealSy90
The D21 "left hand ports" brake master are the same port configuration as RHD S-chassis. They bolt right on. Just have to get the correct bore size that you need for your brake setup.
Old 06-08-2020, 06:11 PM   #11
economix
economix's Avatar
Yea man, I totally ordered one for Thursday delivery. Thanks for the info and input, I was legit fretting this all weekend and some of the used OEM stuff was $200-300 while a new was even worse. I’m grateful that I found this thread. Who knew the search tool here actually worked?!
Thanks again.
