Wanted to Buy Post your needs and wants here. |
sr20 power steering elbow fitting
In search for an sr20 power steering pump elbow fitting, pictured below. Even if you know of one for sale or can link me an alternative(-an fitting) that would be appreciated!
I thought about doing that but assumed that the tap wouldn't be able to get enough threads tapped in the pump before hitting the back of that spot. I'll give it a shot, thanks!
Dont tap the hole.
The ARC PS pump fittingd are a direct fit to those two fitting and converts to AN6 and AN10. From there you can either keep the AN fittings or just us AN to barb 90 (or whatever angle you need) and done P.S The KRC flow fitting is a direct fit to the low pressure (big) side as well. Also, you can just run a 16(??)mm to AN10 and go from there. Lots of options without having to search for an impossible to find fitting. |
