Old 05-14-2023, 08:29 AM   #1
RedSled
RedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-known
Ka automatic bellhousing
Can anyone confirm if the ka automatic bellhousing and the sr20 automatic bellhousing are interchangeable on either automatic transmission,
ie. the sr20 automatic bellhousing can work on the ka automatic transmission and vice versa
RedSled is offline   Reply With Quote
Old 05-15-2023, 07:42 AM   #2
AKADriver
AKADriver's Avatar
Yes. They're the same Jatco RE4R01A trans. In fact other than the tailshaft housing/rear mount it was also used in a bunch of Mazdas. Theoretically that Jim Wolf KA/SR/RB/VG auto bellhousing-to-CD009 adapter kit might work to put a CD009 behind a Mazda 13B...!
The trans cooler lines may be plumbed differently I'm not sure. I've seen a couple different styles. But the connection points on the transmission case are the same so you could swap them over.
