Old 02-02-2005, 07:19 PM   #1
blubottlemax
blubottlemax is an unknown quantity at this point
Front Tire rub, 235/45/17's....
I just got some new tires put on my FNO1RC's, 17x8 w/235-45-17s. They are 35mm offset, with a 1/4 spacer. I didn't have a problem with my 225's, but my 235's are rubbing the fenderliner. Anyone know a quick fix? Thanks in advance.
95 240sx
Got KA-t?
blubottlemax is offline   Reply With Quote
Old 02-02-2005, 07:20 PM   #2
Dousan_PG
Dousan_PG's Avatar
remove the fender liner
problem solved
Aaron
Pink GodziRa
Old 02-02-2005, 08:17 PM   #3
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
watch out if you have a CAI, and it rains heavily
Pank is offline   Reply With Quote
Old 02-02-2005, 09:00 PM   #4
blubottlemax
problem solved
Is this a regular solution for this problem? I had though about it, but I was worried about exposing the underlying sheetmetal to the elements all the time...
95 240sx
Got KA-t?
Old 02-02-2005, 09:14 PM   #5
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
my 225s rubbed the top of my fender on my s13, so i raised the car about a 16th of an inch, and it stopped. It still rubs the plastic part of the fender liner when i turn hard over, but it doesnt scrape much at all, and doesnt really do much damage.
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 02-02-2005, 09:23 PM   #6
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
i got 215's on my fn01r-c's that are 17x8 +35 and when i turn lock my tire rubs the linning as well. will the tire or linning get damaged? im skurred
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 02-02-2005, 09:39 PM   #7
Dousan_PG
Dousan_PG's Avatar
yeah youll rub a hole thru it eventually
yes is a common problem, lose the lining
i havent had one in either car for over 2.5 years
then again i dont have to worry about snow and shit like that
but yeah i wouldnt worry at all.
Aaron
Pink GodziRa
Old 02-02-2005, 09:39 PM   #8
andrewrr
andrewrr is an unknown quantity at this point
just remove the lining, make sure there are no wires exposed to the wheel though.
don't worry about a little bit of rubbing it won't hurt anything. i'm sure doing a burnout or drifting will put 100000x's more damage to your tires than a little rub at full lock.
andrewrr is offline   Reply With Quote
Old 02-02-2005, 10:32 PM   #9
blubottlemax
heh heh, its not a little rub at full lock... at about 3/4 turn it begins to rub, just normal driving... especially with my tein tie rods... eh, I'll pull the fender wells off this weekend...
95 240sx
Got KA-t?
Old 02-02-2005, 10:33 PM   #10
Dousan_PG
Dousan_PG's Avatar
yeah
and if you still rub
break out the propane torch and mallet
hammer away.
problems solved in about 1 hour max
Aaron
Pink GodziRa
Old 02-02-2005, 11:41 PM   #11
mike2016
mike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enough
your tires are too fat for 17x8, maybe 235/40/17 works, or 225/45/17 or something even smaller. i use 235/40/17 on 17x9.5.
mike2016 is offline   Reply With Quote
Old 02-03-2005, 01:53 AM   #12
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
lose the liner
infinitexsound is offline   Reply With Quote
Old 02-03-2005, 02:08 AM   #13
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
freak i just ordered 17 by 9 offsets +17, nd i wanted to put 245s in front. would it stick out?
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 02-03-2005, 03:34 AM   #14
andrewrr
17x9 with 215/45/17 is good. absolutely no flex in the tires and handles like a dream on track, kinda stiff if you're a whiney biatch though. I don't understand why people on this forum think stretched tires are rice? my friend's had 205 on a 9".
Old 02-04-2005, 09:30 AM   #15
s13srmadness
s13srmadness's Avatar
s13srmadness is an unknown quantity at this point
Send a message via AIM to s13srmadness
i am also getting 17x9 +17 with a 245 40 17 on an s14
you need to roll the fenders and maybe pull a little.
i want grip so i run the 245 on a 9.
i also drift and it will be fine for drift.
some people like the stretch for drift, others dont.
not all pros even bother with the stretched tires.
zenki s14
s13srmadness is offline   Reply With Quote
Old 02-04-2005, 10:04 AM   #16
Sil Beer S13
Sil Beer S13's Avatar
Sil Beer S13 is on a distinguished road
Send a message via AIM to Sil Beer S13
yeah
hammer away.
I did that but in still rubbing right below my strut mount.
Sil Beer S13 is offline   Reply With Quote
