Old 02-08-2005, 03:12 PM   #1
NismoDan
NismoDan's Avatar
NismoDan is an unknown quantity at this point
ST Sway bar hardware?
I recently picked up a set of the Suspension Technique sway bars for my S13, but I got it really cheap so it's JUST the bars...like, just the metal things.
I don't have any of the bushings or brackets or anything, and I doubt that the stock ones will fit over the new bars (besides the fact that theyre probably way old and cracking, and the ST ones are poly-eurethane).
Does anyone know where I can buy just the mounting hardware (and instructions would help too ).
Thanks!!
C4L #34
NismoDan is offline   Reply With Quote
Old 02-08-2005, 03:19 PM   #2
stillmatic
stillmatic's Avatar
stillmatic is on a distinguished road
I got a brand new rear sway bar hardware kit. It's missing 1 U bracket but I will include a stock one cut in half to accomodate the missing piece. I'm asking $25.
stillmatic is offline   Reply With Quote
Old 02-08-2005, 06:30 PM   #3
projectRDM
projectRDM's Avatar
ST sells all the hardware separately. Contact a dealer or call them directly. Or, if you know anyone else who has a set, they include a parts list with the instructions.
FORMERLY R240NA
Old 02-08-2005, 08:51 PM   #4
Mark95TT(ATL)
Mark95TT(ATL)'s Avatar
Mark95TT(ATL) is an unknown quantity at this point
Here are the ST part numbers, quantities, descriptions you need --
rear bar endlinks:
2 x 113200 pivot bushing
8 x 113000 end link grommet
2 x 114020 bushing bracket
2 x 110255 3/8"-16 nylon lock nut
2 x 112410 1-3/4" spacer tube
8 x 112502 cupped washer
2 x 112130 3/8"-16 x 5.5" HHCS
front bar endlinks:
2 x 112406 spacer tube
2 x 113175 pivot bushing
8 x 112518 flat washer
2 x 112018 10mm-1.25 x 30mm HHCS
4 x 110625 flat washer 3/8"
These are for the S14, S13 may be slightly different.
Mark95TT(ATL) is offline   Reply With Quote
Old 02-08-2005, 09:39 PM   #5
S14DB
AFC #1
S14DB's Avatar
you can get ES stuff at your local autoparts store.
Old 02-09-2005, 12:15 PM   #6
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
Thanks!!
here are the part numbers for for the hardware kit:
front:50090-777
rear:51065-777
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 02-17-2005, 09:04 PM   #7
NismoDan
NismoDan's Avatar
Thanks to everyone for helping me out, especially kuruptR.
The only thing now is, where should i go with these parts numbers to order the parts?
The ST website is shut down, I think, and I dont know who carries their stuff.
Thanks again!
C4L #34
Old 02-18-2005, 07:49 AM   #8
Mark95TT(ATL)
Call ST directly, they can help you out.
Suspension Techniques
(800) 595-7016
