Old 02-11-2005, 02:52 AM   #1
csdcowboy
csdcowboy's Avatar
csdcowboy is an unknown quantity at this point
Timing chain done...now a rough idle/low power issue! Help!
Alright well I did the timing chain kit on my stock ka24e this last weekend (using http://www.240sx.org/links/installs/timing_chain/). Went fairly well, but took like 12 hours (that includes driving around getting things we forgot...doh!). She started right up and no rattle....oh so nice
Anyways, she's running rough at idle. Sounds kinda like a V8 or something, so I'm assuming it's missing. The reasons for this that I've come up with are:
1. I cracked the mount on the distributor when I was replacing it because I tried to mount the dist. with the spindle indside the front cover. It didn't crack all the way across, but it's pretty substantial. I'm thinking maybe that's throwing my timing off or making me miss or something.
2. I've done some researching (here, mostly) and now I'm wondering if maybe it's the MAFS?
Anyone have any other ideas, things I can check? I've got a new dist. coming in the mail, so that'll be fixed. Any knowledge is appreciated
csdcowboy is offline   Reply With Quote
Old 02-11-2005, 07:08 AM   #2
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
you should check your timing.. playiing with the timing chain & distributor can alter the timing.If your timing is off you can have idle issue and low power like you discribed
good luck
F3600 is offline   Reply With Quote
Old 02-11-2005, 07:12 AM   #3
amolao
amolao's Avatar
amolao is an unknown quantity at this point
This is basic troubleshooting, ....get a good distributor cover and check your timing....is got to be one of those things....
http://home.sw.rr.com/longstorenissan ***UPDATED 13 AUG 05 ***
amolao is offline   Reply With Quote
Old 02-11-2005, 07:45 AM   #4
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
unless you put the chain on backwards...you DID check didnt you?
oh man now you're gonna have to do it all over again!!!
I keed i keed, good luck fixing it
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 02-11-2005, 08:47 AM   #5
Titan
Titan is an unknown quantity at this point
You aligned the silver links on the chain to the punchmarks on the sprockets when the motor was at TDC on the compression stroke of #1 right?
You also slid in the oil pump with the two punchmarks aligned?
Other then that, you might have to try a new cover.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 02-11-2005, 09:42 AM   #6
bobafett
bobafett is an unknown quantity at this point
matt i have a dizzy off my sohc motor that i just picked up from sean in hillsboro, call me up if you are interested.. alex said he thought yours mihgt need replacing, but didnt know if u already ordered one...
email is [email protected] if you lost it...
bobafett is offline   Reply With Quote
Old 02-11-2005, 11:21 AM   #7
o5i2
o5i2 is an unknown quantity at this point
Send a message via AIM to o5i2
same thing happened to me before. check to make sure all your hoses are connected first. i found out one of mines was partially off, causing a rough idle/low power.
-barry
o5i2 is offline   Reply With Quote
Old 02-11-2005, 03:28 PM   #8
csdcowboy
csdcowboy's Avatar
CHRIS - You've got mail!
CRAP!!! I knew we forgot something!!
Yeah, we aligned the silver links with the marks on both gears while at TDC on piston #1.
Just to clarify, I cracked the mounting portion (the metal), not the plastic cover. I wish I had pics, but my batteries are dead in my camera.
Old 02-13-2005, 08:21 PM   #9
csdcowboy
csdcowboy's Avatar
Well.....none of the above! I checked the vacuum hoses and stuff and those were all fine. So I checked the throttle position sensor like I'd read about, making sure it got enough voltage or something. It seemed to be fine, but when I put my voltmeter on the middle wire (there's 3), the engine cleared up and she sounded perfect, even when I revved it.
So yeah....wierd. I'm gonna get a new tps tomorrow and I'm pretty sure that'll fix it. Either that or my wiring's fucked.
Old 02-14-2005, 08:57 AM   #10
sykikchimp
WOW addicted
sykikchimp's Avatar
Or maybe you just need to make sure the ground is good.
