Old 02-20-2005, 12:32 AM   #1
Campos
Campos's Avatar
Campos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura about
Send a message via AIM to Campos
Cool spray while at full booooooost?
hey i'm curious, I know people with na's and when the spray its from the launch till the end. can you do the same with turbo? like on an sr for instance? i was thinkn of maybe a 75 shot, i wanna run 10's...so thats my reason.
Parting out SR build....
Campos is offline   Reply With Quote
Old 02-20-2005, 11:15 AM   #2
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
spray is for pussies, thas the easy way out, take ur sr, be a man and do some engine work, to gain the power u need. ps sorry if i offened anyone by sayin pussy, but i dont like the use of spray, its pointless to me and i dont like it,
sil80forme is offline   Reply With Quote
Old 02-20-2005, 11:18 AM   #3
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
using nitrous for 10's would be the pussy way out since you can do that without nitrous. Do you realise how much money its going to cost to be able to run a 10? Even more so to be able to do it more than once and repeatidly? Save the nitrous for when everything else is completly maxed out, thats when you need it
wootwoot is offline   Reply With Quote
Old 02-20-2005, 01:31 PM   #4
S15 Powered
S15 Powered is an unknown quantity at this point
Send a message via AIM to S15 Powered
Seriously, unless you live at the track you have no reason to go out and get nitrous. And even if you do live at the track, it's not like you're straight up drag racing. Consistancy means more than speed anyway. A good set of drag radials and launching ability will probably make up as much if not more time than a 75 shot of gas.
S15 Powered is offline   Reply With Quote
Old 02-20-2005, 01:52 PM   #5
Campos
Campos's Avatar
look i was just curious, i didn't say i was goin to do it or that i even like it. i wasn't asking if i would be considered a pussy or not. Yes it will cost a lot to run 10's no doubt about that, it cost alot to run 11's and i don't know if my car will do that yet. I ran a 12.9 @ 108 with stock turbo on 17" street tires and also had a full tank of gas if that makes diff. here is my of mods that i plan to have 400whp and run 11's on street tires---- greddy intake man., obx exh man, garret gt2871r .86, jwt s4 cams, greddy fmic, stainless o2 housing, greddy dwn pip, hsk hipower exhs., z32 maf, soon to be enthalpy ecu, dna mbc, kaaz solid hub lsd, apex-i pwr intke, jgy fuel rail w/72lb injectors oh and a cometic head gasket w/arp head studs
Old 02-20-2005, 02:00 PM   #6
wootwoot
You want to run 10's with that setup?? Think big, and if you are saying you are going to do that then redo it later to run 10's your throwing money away. But if you do want to do the set up you have above listed(which would be great for a street/strip car) I recommend going externally wastegated, scott would agree with me here. Get the full race bottom mount exhaust manifold as well. It costs a lot more but is less hassle down the road when you have to take your obx off to get it welded. Everything you have listed on slicks should be good for a high 11, maybe even on pump gas
Old 02-20-2005, 02:08 PM   #7
Campos
Campos's Avatar
its not a question if i want this setup, i already have it all, just in process of puttin it all on.
who make the full race bottom mount manifold? thanks
Old 02-20-2005, 02:10 PM   #8
Campos
Campos's Avatar
also, how do i eliminate the internal w/g ??? and where would be the ideal place on the manifold to have the external mounted?
Old 02-20-2005, 02:13 PM   #9
srpowereds14
srpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to beholdsrpowereds14 is a splendid one to behold
Send a message via AIM to srpowereds14
Some of the D1 cars use nitrous.... i guess there pussys huh
Vertex-USA | Speed Alliance | Memory Fab | TNT Auto Body |
srpowereds14 is offline   Reply With Quote
Old 02-20-2005, 02:16 PM   #10
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
Weld the flapper gate closed. and put the external wastegate where ALL the runners meet.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 02-20-2005, 02:16 PM   #11
Campos
Campos's Avatar
yeah the must be...according to these other assholes
Old 02-20-2005, 02:27 PM   #12
Steeles
Steeles's Avatar
What D1 cars use nitrous? or do you mean nitrous sprayers on the intercooler to keep intake charge temps down?
Old 02-20-2005, 04:19 PM   #13
dunno
dunno is an unknown quantity at this point
Send a message via AIM to dunno
Honestly. He asked if he could spray the entire way down the track, he didn't say, "Hey, can every jackass on this forum please give me your opinion on nitrous?"
-Matt
dunno is offline   Reply With Quote
Old 02-20-2005, 08:23 PM   #14
sil80forme
sil80forme's Avatar
ok the pussy comment was alil extreme, but look if thas what u wanna do then go and do it, i just think u should get the gain in hp from, blood sweat and tears, w/ addin the nessasary parts to do so, not just go HMM i wanna do 10's in the 1/4 so i will get nitrous (the easy way out). its no fun and u dont learn anything about ur car/motor. i do all the work to my car myself and wouldnt have it any other way, there are so many things/parts that u can add, and do urself and get into the 10's W/0 spray, just need the time and tuning to do so. thas all i ahve to say bout that
Old 02-20-2005, 08:32 PM   #15
s156spd
s156spd is an unknown quantity at this point
Send a message via AIM to s156spd
i swear!!!! shut the fuck up!! blah blah blah
my new toy
http://www.andyqbui.com/emotion/tashi/
my old toy
http://evolutionautosports.com/240tashi.htm
s156spd is offline   Reply With Quote
Old 02-20-2005, 08:35 PM   #16
Campos
Campos's Avatar
easy way, i've done all my work myself, every last bit of it! i've put much blood and sweat into my ride. i am the same way, i don't trust anyone but my self to work on my car. all i wanted to do know is if it hurts the motor to spray at full boost. and what would be a somwhat safe set up.
Old 02-20-2005, 08:38 PM   #17
Campos
Campos's Avatar
by the way what do you have done to your sr mr sil80flamer? what have you done thats soo special that no-1 else on this damn forum can do? prob. nothing
Old 02-20-2005, 08:47 PM   #18
ThatGuy
Admin Asshole
ThatGuy's Avatar
Calm down guys, keep it civilized.
Old 02-20-2005, 08:52 PM   #19
Campos
Campos's Avatar
my bad, my bad
Old 02-20-2005, 09:30 PM   #20
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
damn i was on like a 5 or 6 month winning streak, after stayin away from those mustang, camaro, honda forums, I almost lost spray, nos, and bottle pressure from my vocabulary, but now this, ohyvey.
mjjstang is offline   Reply With Quote
Old 02-20-2005, 10:22 PM   #21
sil80forme
sil80forme's Avatar
drft57pro, whats with the flammer shit? and fuk the SR. i refuse to jump on the bandwagon and put that shit in my car, KA-T all the way 256k miles and still runnin strong, custom kit, all done by ME everything on that motor was put together by ME, i never said i had or did anything no one else on this forum could do. i think that to engoy ur car and to be able to respect it, u gotta do all the work that u can ur self and not pay someone to do it.
Old 02-20-2005, 10:26 PM   #22
wootwoot
www.full-race.com
I dont care if a D1 car uses nitrous, that doesnt make it cool in my book. Sorry for not being a slave to the media whores. But you could have the FullRace bottom mount manifold made with an external gate for it, then you would just weld the flapper shut on your 2871r. The FullRace manifold is not cheap at all. But you want to go fast and do it good, so get it. Making personal attacks on people, all of you who are doing so, is rather stupid. Think about what you are doing/saying and act different. Take the criticisim instead of barking back and looking like an idiot
Old 02-20-2005, 10:31 PM   #23
sil80forme
sil80forme's Avatar
yeah u tell us all wootwoot i know u include me in that comment, but hey just have a bit of fun! thas all. CANT WE ALL JUST GET ALONG?
Old 02-21-2005, 12:33 AM   #24
Campos
Campos's Avatar
yeah its all good, i apologize
we should all be here to help each other out n stuff
Old 02-21-2005, 12:40 AM   #25
sil80forme
sil80forme's Avatar
nice so we are all good and everyone is happy, time to go to bed
Old 02-21-2005, 05:15 PM   #26
undercoverdjay
undercoverdjay is making a name for him/her selfundercoverdjay is making a name for him/her self
Send a message via AIM to undercoverdjay
i usually just run a quick shot of hairspray through my SR. I also make sure to put a potato in the downpipe. Makes for a good show =-)
undercoverdjay is offline   Reply With Quote
Old 02-21-2005, 06:44 PM   #27
ruthlesstyper
ruthlesstyper is an unknown quantity at this point
haha
Why is everyone pissed about him using nitrous. Stupid. He just wants an answer to his question. If he wants to do it, he will even with all of you guys flaming him.
ruthlesstyper is offline   Reply With Quote
Old 02-21-2005, 06:56 PM   #28
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
i didnt know full-race made t-2 flanged mani's. i guess anything for a price
Hi
Var is offline   Reply With Quote
Old 02-21-2005, 07:05 PM   #29
wootwoot
^^^^ dingggggg. They make anything you want
Old 02-22-2005, 12:41 AM   #30
srpowereds14
The ones that i saw at the D1 event at fontana were the yellow ae86 from UPGARAGE and the blue s15 greddy car i think there were more it seems more and more common that they use the nitrous for probably off the line when the start the run... i looked at there FMIC and didn't see any sort of sprayers for the cooler
