Old 02-27-2005, 01:30 PM   #1
AadosX
AadosX is making a name for him/her selfAadosX is making a name for him/her self
Send a message via AIM to AadosX
S14 LCAs on S13?
You guys think there would be any issues as far as handling characteristics resulting from using the S14 LCAs on my S13 while doing the 5 lug swap? I know they're 10mm longer so I'm wondering. I know there will be more neg. camber, but I'm wondering about the wider wheelbase in the front.
Your two cents?
Thanks,
John
AadosX is offline   Reply With Quote
Old 02-27-2005, 02:44 PM   #2
idlafie
idlafie's Avatar
Your two cents?
Thanks,
John
Uhhh....I know this doesn't answer your question, (and apologies for going somewhat off-topic), but why didn't you just remove your old S13 LCA's and have a shop press in S14 ball joints?? I recently helped my buddy do a 5 lug swap on his S13 and that's what we did. We took his LCA's to a local mechanic & had the mechanic press in the S14 ball joints. All it cost my buddy was cost for the part, an hour's time & 20 bucks labor for pressing in the S14 ball joint.
Anyhow, sorry to be such a nag...
ID
Old 02-27-2005, 05:47 PM   #3
projectRDM
projectRDM's Avatar
Slightly increased negative camber, more turn in bite. 10mm is hardly a noticeable difference, and the change is at the bottom of the wheel anyway.
FORMERLY R240NA
Old 02-27-2005, 08:42 PM   #4
Phil St John
Phil St John is an unknown quantity at this point
Ok so I'm No ultra mighty mechanic but depending on how far away the wheel is ftom the arm 10mm is a whole lot of change in angle. That 10mm could be as much as 17degrees. I havent gone out and measured the factory geomety but now i think i will. The greater the distance the more noticable the degree of change, your tire wear might be uneven but i don't think its unsafe. Please explain why 10mm would be negatable? I'm not tryin to be a jerk, I'm just a little confused. It's hard 2 switch from music mode to thinkin about car stuff so maybee I'm just high.
Phil St John is offline   Reply With Quote
Old 02-28-2005, 07:39 AM   #5
projectRDM
projectRDM's Avatar
You are high. 10mm is less than a half inch, and that entire gain is at the bottom fulcrum point. Numerous people run this setup fine and there's very little wear if the toe is set right. For autocross/track use it's ideal. A set of camber plates can be used to pull it back in if so desired, allowing for even more fine adjustment.
FORMERLY R240NA
Old 02-28-2005, 11:39 AM   #6
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
I doubt it, moving the front LCA arm out 10mm is a HUGE difference, it may not matter to most 240 guys because they seem to runs lots of negative camber anyways.
P.S. Even just over a 1/4 inch is a major change in camber, everything being left the same and just the LCA is pushed out 10mm.
CHARLIE2020 is offline   Reply With Quote
Old 02-28-2005, 05:16 PM   #7
AadosX
Ok, since apparently people can't read very well... I'm asking about anything BESIDES CAMBER. Thankyou for the replies, but I'm not worried about camber at all. Camber plates as far as I'm concerned are a neccessity PERIOD, and will be on my car.
Old 02-28-2005, 06:00 PM   #8
Flybert
Apparently you weren't reading Russ' reply. He mentioned how it effects handling. Also, widening the track using the LCA's rather than running lower offset wheels helps with scrub radius. Of course, if you are like me, you wouldn't mind just running S14 balljoints on your S13 LCA's so that you can get a lower offset wheel just for the look and for tire rotating purposes.
