Old 02-28-2005, 02:28 AM   #1
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
stop lamp question...
my problem is that my stop lamps dont work... my tail lights work when i turn on my lamps, but when i break they dont get brighter. before that my tails were working flawlessly. i was wondering if there were any relays or anything close to that that would make them not work anymore... they worked intermittantly before... when they didnt work, i would fiddle with the switch where the break pedal is connected to... but now they dont work at all... what would make only my stop lamps not to work? my bulbs arent burnt neither and i am using the right bulbs...
s13silady is offline   Reply With Quote
Old 02-28-2005, 02:55 AM   #2
luckie2hav3her
luckie2hav3her is an unknown quantity at this point
Send a message via AIM to luckie2hav3her
...fuse....?
luckie2hav3her is offline   Reply With Quote
Old 02-28-2005, 03:29 AM   #3
goodjuan
goodjuan's Avatar
goodjuan is an unknown quantity at this point
Send a message via AIM to goodjuan
could be a lot of things, but i know very very common problem with s13s (including mine) was that the connections on the tail light bulb wires would melt the plastic they were screwed into and thenthe plastic would flow in between the connections opening the cuircuts. pop those tail light assemblies out and unscrew and re connect all the connections...hopefully that helps man
goodjuan is offline   Reply With Quote
Old 02-28-2005, 05:03 AM   #4
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
may be try to use some better bulbs like PIAA?
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
Old 02-28-2005, 07:33 AM   #5
projectRDM
projectRDM's Avatar
You answered your own question. Replace the switch.
FORMERLY R240NA
Old 02-28-2005, 01:42 PM   #6
s13silady
s13silady's Avatar
i did replace the switch... i dont know if it would make a difference, but i have an SR and i have 2 switches... i look at all my other buddies 240's and they all have one... theres also a relay looking thing that they both connect to... is it common for these things to go out?
Old 02-28-2005, 02:21 PM   #7
projectRDM
projectRDM's Avatar
There's a brake switch and a clutch cancel switch. Brake switch wires are red/yellow and red/green. Swap that one.
The 3pin unit is the flasher.
FORMERLY R240NA
Old 03-01-2005, 02:01 AM   #8
s13silady
s13silady's Avatar
would you mind explaining the clutch cancel switch? if we are talking about the same switches, then there are 2 switches for the brake pedal...
Old 03-01-2005, 09:20 AM   #9
projectRDM
projectRDM's Avatar
Dammit. Cruise cancel switch.
FORMERLY R240NA
Old 03-01-2005, 09:28 AM   #10
Ritz S14
Ritz S14's Avatar
There there it's okay.
Ritz S14 is offline   Reply With Quote
Old 03-01-2005, 12:15 PM   #11
s13silady
s13silady's Avatar
hahaha... i replaced that already... but i replaced it with a uber leet JDM one from my friends front clip... but maybe that was burnt out too...ill give it a try...
thanks for your help so far BTW.
