Old 03-01-2005, 12:10 PM   #1
sr20tom
sr20tom's Avatar
sr20tom is an unknown quantity at this point
SR Throttle cable not lining up
on my 90 240sx the cable lined up with the sr motor using the jdm bracket. Now that i totaled that one, i got a 91 and the throttle cable is not lining up for some reason. Are there any suggestions on how to fix this problem?
sr20tom is offline   Reply With Quote
Old 03-01-2005, 01:12 PM   #2
Flybert
Make your own extension bracket.
Old 03-02-2005, 08:57 AM   #3
a2low240
a2low240 is an unknown quantity at this point
Send a message via AIM to a2low240
Bend the gas pedal to allow for more slack on the motor side. Make sure that there is no stress on the TB when the car is floored or you will break it and send screws into your manifold / engine.
Signature Exceeds Forum Limits
a2low240 is offline   Reply With Quote
Old 03-02-2005, 10:05 AM   #4
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
i would just bend the bracket that holds the throtle cable....you probably dont' want to mess with bending your pedal. if you want i can send you pictures if you email me. [email protected]
g2ic02 is offline   Reply With Quote
Old 03-02-2005, 11:00 AM   #5
timmybgood
timmybgood is an unknown quantity at this point
seems like the gas pedal would be pretty hard to bend..
i had the same problem when i put mine in. with the SR bracket the throttle cable was close but wouldn't reach the TB. so i put on the bracket from the KA and with a little bending it fit perfect
1995 SE
timmybgood is offline   Reply With Quote
