Old 03-06-2005, 01:41 PM   #1
matt0481
matt0481 is an unknown quantity at this point
Anyone else have ignition switch trouble?
My ignition switch had gotten where I had to jiggle the switch to crank it. I finally took the column apart and found that the switch had started coming away from the cylinder via the screw that holds it to the key cylinder. The crimping that holds it into the metal case was also poor. So, I took a screwdriver and tapped the crimps again and tightened up the screw that held it to the cylinder and those troubles are over.
matt0481 is offline   Reply With Quote
Old 03-06-2005, 04:49 PM   #2
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
my ignition switch also was acting weird, so I just put in a push button start. also gave me some time to wire in a fuel pump kill switch.
papershot is offline   Reply With Quote
