Old 03-07-2005, 01:42 PM   #1
joel
joel is an unknown quantity at this point
Send a message via AIM to joel
Need to get 240 Running!!! HELP
ok, i have a 91 240 5sp. and i have had alot of problems with it lately. At first, It started as after the car would warm up it wouldnt want to start. if it was still cold then it would start fine. but when warm it would just continually crank and smell like fuel. then after a few months of that, now its hard to start all the time. It will try to crank first, then die. then ill do it again, it will start but immediately die. then about on the fourth time, it will stay running but will sputter and hesitate while driving. I really need to get this fixed, please help if you can. i think someone was saying its maybe a leaky injector or something but im not sure. thanks in advance joel
joel wikle
joel is offline   Reply With Quote
Old 03-07-2005, 04:07 PM   #2
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
i would check the mafs and do stuff like change spark plugs, wires, Cap & Rotor...i think there are a lot of people on here that have had similar problems
g2ic02 is offline   Reply With Quote
Old 03-07-2005, 05:29 PM   #3
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
sounds like your getting too much fuel, check that you're getting proper spark... if that's good, check the MAFS like stated above.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 03-07-2005, 06:13 PM   #4
joel
but if i was getting too much fuel than couldnt that possibly be a fuel injector leaking issue ? what should i do to check the mafs? ive pulled it off and it looks pretty clean in there. thanks for the suggestions guys! keep them coming
joel wikle
Old 03-08-2005, 07:35 AM   #5
the head
the head's Avatar
Location: in a dark room mastering the art of typing with one hand
the head is making a name for him/her selfthe head is making a name for him/her self
have you changed the plugs/wires/cap and checked the coil? run some injector cleaner through it also if none of those work then pull your fuel rail and look at the injectors
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
