Old 03-31-2005, 09:37 AM   #1
BlazedGlory
BlazedGlory will become famous soon enoughBlazedGlory will become famous soon enoughBlazedGlory will become famous soon enough
Question <=400whp Goal - Exhaust Manifold Options?
In the very near future I plan on doing some major upgrading to my redtop. My goal is for 400whp at the most. I've been trying to search for some info on manifolds, but I'm having some problems finding all the information I need.
It seems that it is accepted fact that equal length manifolds are best. I've tried to search for some options, but am having some hard times. I'm sure I'd be happy with a full-race manifold, but I don't really want to fork out that kind of money. What other companies make reliable equal length manifolds that don't cost $1000? Is there such a company?
What kind of difference would there be if I didn't go with an equal length manifold? What are some good companies that make non-equal length manifolds?
Thanks in advance...
BlazedGlory is offline   Reply With Quote
Old 03-31-2005, 10:34 AM   #2
Mike Wazowski
Mike Wazowski has a little shameless behavior in the past
You have to decide and tell us whether you are going top or bottom. Are you going internal or external? Then we can give you suggestions.
Mike Wazowski is offline   Reply With Quote
Old 03-31-2005, 12:16 PM   #3
Rusker
Rusker's Avatar
Rusker is on a distinguished road
Quality costs money...
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 03-31-2005, 01:51 PM   #4
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Why would you go topmount? Just for looks? You can fit a capible turbo on a bottom mount just fine.
I reccomend, Silk Road Manifolds (signal), hks.
all the cheap ones crack.
I use silk road
blu808 is offline   Reply With Quote
Old 03-31-2005, 03:41 PM   #5
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Fullrace is the only true option to consider at this point. Their bottom mount is 850 I think?
wootwoot is offline   Reply With Quote
Old 03-31-2005, 03:45 PM   #6
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
a megan manifold will hold
kensreliableb18b is offline   Reply With Quote
Old 03-31-2005, 06:30 PM   #7
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
I use silk road
400rwhp.....?
top mount is for big turbos. if u use anything bigger than a t3 centersection on a low mount, the position of turbo ends up very close to oil return bung on motor, then u dont get adaquate oil drainage. not to mention snaking the intake piping past the powersteering is a b@tch.
i am running a t3/t4 with about 63a/r housings. compressor side fits with 1 finger space between motor and snail, oil return line is barely an 1 1/2" above bung. 400rwhp is alot out of an sr, thats pretty dyno queen in my opinion, which leaves u running something big, which will in my opinion necessitate top mount to fit.
and yes cheap ones crack. at 400 horse, u will be running pretty crazy boost, with retarded timing, that leaves u with high egt's and cheap ones crack when u turn them into cherry pipes. ive never seen above 370rwhp without high egt's and some crazy boost/retarded timing. but then again, hawaii is small and noone does dyno queens/quartermilers.
ultraDorksGarage is offline   Reply With Quote
Old 03-31-2005, 07:20 PM   #8
Campos
Campos's Avatar
Campos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura about
Send a message via AIM to Campos
i have a megan w/gt2871r .86 should be good combo for anyone lookin to hit the 400 whp range.....jwt s4 cams, greddy intake man. ect ect and a enthalpy ecu.....
Parting out SR build....
Campos is offline   Reply With Quote
Old 03-31-2005, 08:25 PM   #9
wootwoot
with the .64 gt2871r you can hit 400rwhp. That number is not dyno queen if you set it up right. 400whp is a lot of a stock sr, not a lot for an sr.
Old 03-31-2005, 09:25 PM   #10
Mike Wazowski
899 + ship (about 20 anywhere in the u.s.)
wastegate is 100 dollar option
dumptube for wastegate is another 100 dollar option
Old 03-31-2005, 09:26 PM   #11
Mike Wazowski
400rwhp on a 0.64? wow i would love to see that. really.
Old 03-31-2005, 09:46 PM   #12
wootwoot
Go on Freshalloy if you want to see actual technical date.That is with exhaust manifold, cams, intake manifold and about 18-20 psi though; So its pushing it but definitely doable on pump gas
Old 03-31-2005, 10:01 PM   #13
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
I always thought that 400 +hp was the .86... its good to hear the .64 can do it also.
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 03-31-2005, 10:35 PM   #14
Campos
Campos's Avatar
i have the .86 and it works great...not laggy at all....i love it...especially at 21psi
Old 04-01-2005, 12:36 AM   #15
ultraDorksGarage
400rwhp off of a gt28 + 21psi? i went with the wrong combo, damn thats sick!!!!! how long can u boost at 21 psi?
lots of people i know went for strokerkits and gt28**, mainly for mountain runs. average is 350-360rwhp at 1.2 bar boost.
i was wondering, how does the car react to more rpm(of course building it for such)? ive been contemplating building my sr for about 1.2-1.4 bar boost and about 8-8.5k rpm. the usual stuff of course, but wondering how it stacks up to the stroker kits...
i figure its a little cheaper to get the car to rev up there compared to getting a decent stroker set up and wanted to know if its worth it.
Old 04-01-2005, 07:26 AM   #16
Campos
Campos's Avatar
8k is doable on just some comp cam valve springs @ $150, but don't forget the rocker arm stoppers.
