Old 04-09-2005, 12:58 PM   #1
tokes¹
tokes¹'s Avatar
tokes¹ is an unknown quantity at this point
Send a message via AIM to tokes¹
autopower rollbar install w/pics.....(56k.maybe?)
I helped my friend(redSthirteen) install an AutoPower RollBar on his s13 the other day and i took enough pictures to post the install process.
tools:
14mm socket
14mm open wrench
drill (make sure the battery is fully charged!..LoL)
100mm hole saw
jack and jack stand
silicone sealer
install time: id say about 3-5 hours. it took us alil longer because we had to sit around and let the battery charge for the drill.
remove front and rear seats...
now slide the rollbar inside and dry fit it....
we had to get alil creative due to lack of tools and use a screwdriver to determine where to drill the hole in the rear panel...LoL
now drill the holes and install the mounting bolts...
make sure you put some sort of silicone sealer around the bolt holes between the plates to prevent water leakage.
now put back everything that you removed and youre done!...
and they said no one could sit in the back.....LoL
we took it for a test drive and the difference was like night and day.
thats all for now.
watch out for this car when youre out on the backroads..
tokes¹ is offline   Reply With Quote
Old 04-09-2005, 01:15 PM   #2
Ritz S14
Ritz S14's Avatar
Very nice!! How much did it cost?
Sure if you want to bust your balls.
Ritz S14 is offline   Reply With Quote
Old 04-09-2005, 02:16 PM   #3
Andrew Bohan
classic pic dude
Old 04-09-2005, 03:08 PM   #4
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Can the seat move all the way back? I have been looking at a roll bar for part of my plan, but didn't know if an autopower bar would accommodate the seat all the way back. I'm a big guy, so I need my space!!
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 04-09-2005, 03:18 PM   #5
StudentDrifter
StudentDrifter is an unknown quantity at this point
Looks good
StudentDrifter is offline   Reply With Quote
Old 04-09-2005, 03:59 PM   #6
tokes¹
tokes¹'s Avatar
if i remember correctly it cost him around 450 and it took about a month to make.
yea i pushed the seat all the way back just to see the clearance. the seat can go all the way back on the rails and recline about 3-5 clicks before hitting the bar on the back.
Old 04-09-2005, 06:09 PM   #7
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Cool......thumbs up for the DIY.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 04-09-2005, 06:14 PM   #8
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
did it make any difference with your handling?? decrease chassis flex any??
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 04-09-2005, 06:20 PM   #9
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
looks like your friend started w/o a sunroof already so it should have already been decently stiff to being w/
91CRXsiR is offline   Reply With Quote
Old 04-09-2005, 06:49 PM   #10
Drunk Bastard
Drunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really nice
Send a message via AIM to Drunk Bastard
is it possible to squeeze a wheel (or two) in the back? is there enough clearance between the bar and the roof?
Drunk Bastard is offline   Reply With Quote
Old 04-09-2005, 07:50 PM   #11
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Wouldnt happen to know the shipping weight would you?
wootwoot is offline   Reply With Quote
Old 04-09-2005, 07:58 PM   #12
tokes¹
tokes¹'s Avatar
i was only able to drive it for about 5-10 mins but i felt a dramatic change in the handling. no more body flex and the rear breaks out alot easier.
mmm i think you can squeeze 2 tires in the rear and maybe 2 tires in the backseat sideways. the rollbar fits like a glove...we had to remove the lense cover from the interior light to prevent it from cracking.
not at the moment but i can ask next time i talk to him. but that badboy was heavy!
Old 04-09-2005, 08:28 PM   #13
ThatGuy
Admin Asshole
ThatGuy's Avatar
SCCA Legal? It's a nice looking cage, just want to make sure it meets the requirements before I buy one and try to go to the track.
Old 04-09-2005, 08:45 PM   #14
Drunk Bastard
tokes1, im talking about right here (in the picture) can you test fit a tire between there and see if it will go into the back seat? I'm gonna be getting this roll bar eventually and want to know if i can fit my extra tires in the back...
Old 04-09-2005, 08:54 PM   #15
TiNMAN
TiNMAN's Avatar
hmm, if that doesnt work try the bottom left. it really depends on the wheel itself, im sure you can slip somethin through the opening in the bottom left. not so sure about an s14 though, our seats might be a little higher(more cushon). hmphh, let us know if you work somethin out tokes. im also interested, right on man
I AM LEGIT.
TiNMAN is offline   Reply With Quote
Old 04-09-2005, 09:04 PM   #16
tokes¹
tokes¹'s Avatar
yup its scca legal. he paid extra to make sure it was race legal.
hmmm ill have to try next time i see him (remember this was my friends car). i dont think the tire will fit through that blue area you highlighted in the picture. but you get a tire to fit sideways in the backseat if you go through the back hatch (thats how my friend got out the backseat after taking that hilarious picture) im sure you can fit 2 tires in the back sideways...1 tire per seat.
it will work if you go from the back..
Old 04-09-2005, 09:09 PM   #17
Drunk Bastard
...i have an s14...so going through the rear isnt an option.
Old 04-09-2005, 09:16 PM   #18
tokes¹
tokes¹'s Avatar
ohh haha duhh! LoL
the good thing is that the middle part is removable. just pop out the bolts and you can place the bar in your trunk and youll beable to place tires in the backseat without a problem. then just bolt back up the middle bar and youre good to go.
just remove the bolts...
Old 04-09-2005, 09:30 PM   #19
Flipzide
Flipzide's Avatar
Flipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfection
thanx for the install info, been looking for something like this ^^
D-Street.net | bcuison.wordpress.com
Flipzide is offline   Reply With Quote
Old 04-09-2005, 10:58 PM   #20
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
hmm..... is that a dude in the back seat??? wow could make a qutip out u
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 04-10-2005, 12:18 AM   #21
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
could you take a picture between the roof and the bar to really see how snug it is
Heartwork is offline   Reply With Quote
Old 04-10-2005, 12:31 AM   #22
wootwoot
hahahah. I love how you give instructions with drawings; I feel like I'm in an planetarium! Sucks it was so heavy. Espicially with a majority of it being rather high up. Looks like I'm still going to havOe to make mine out of cf or titanium. Theres also my option of becoming some crazy chemist. Easier yet I could quit driving like a jack ass and not worry about landing upside down...
I'm from Florida so I'm probably a bit more strange than you
Old 04-10-2005, 12:45 AM   #23
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
so where did he buy it from?
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 04-10-2005, 01:42 AM   #24
ohnobigtdawg
ohnobigtdawg is an unknown quantity at this point
loving all this visual aid!
MR. Pibb + Red Vines = Crazy Delicious
You can call us Arron Burr by the way we droppin Hamiltons!
ohnobigtdawg is offline   Reply With Quote
Old 04-10-2005, 02:04 AM   #25
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
is that a wyotech jacket?
just wondering why you guys choose to put the bolt on the bottom facing up and the nut on top.
BOROSUN is offline   Reply With Quote
Old 04-10-2005, 02:23 AM   #26
Drunk Bastard
what about those with fixed-position-bucket-seats....that cant really move too far forward and CANNOT recline/fold-forward..... hmmm....i want a cage and ALSO want to be able to fit tires in the "back seat" (which is taken out)....i cant jjust go through only two tires per event....
Old 04-10-2005, 02:49 AM   #27
Andrew Bohan
this should solve all your problems joe
Old 04-10-2005, 03:23 AM   #28
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
wait.. you have two fixed buckets? driver and passenger?
KoukiMonster is offline   Reply With Quote
Old 04-10-2005, 03:32 AM   #29
Drunk Bastard
hmmm...didnt know the bar was removable....that makes all the difference in the world.
a good place to order from is IO port racing...
http://www.ioportracing.com/
Old 04-10-2005, 03:54 AM   #30
TiNMAN
TiNMAN's Avatar
ok ok, i say we all chip in and all go in on andrew's idea. PLENTY of space. i got $5 on it!
I AM LEGIT.
