Old 04-18-2005, 03:18 PM   #1
swiftsytles
swiftsytles is an unknown quantity at this point
Eibach Has Alignment Adjustment Kit???
sup, I ordered some eibach sportline springs from tire rack today and they offered me an eibach alignment correction kit for extra $20 dollars. I asked him what was included and he couldnt give me specifics, but that its suppose to bring my alignment back to factory specs. He said that I can return them for my money back if I didnt want them, so why not. Anybody know what they are or if it works?
swiftsytles is offline   Reply With Quote
Old 04-18-2005, 09:07 PM   #2
ucfz31s13
ucfz31s13 is an unknown quantity at this point
Send a message via AIM to ucfz31s13
Call him back and tell him he's an idiot.
ucfz31s13 is offline   Reply With Quote
Old 04-18-2005, 09:36 PM   #3
TK
TK is an unknown quantity at this point
probly front cam bolt, not sure whats included for the rear
TK is offline   Reply With Quote
Old 04-18-2005, 09:38 PM   #4
raging panda
raging panda is an unknown quantity at this point
Send a message via Yahoo to raging panda
yea, its just a big cam bolt that goes in the holes connecting the strut to your spindle, works good, but mine came out of spec after a while and gave me positive camber, i dunno if it was the install or the bolts just came loose, but its worth a try at 20bux. If you can keep them from slipping, the bolts work great and you will be able to adjust your camber.
for your setup, im not sure if theyre going to be needed, because i had coilovers, it was low.
raging panda is offline   Reply With Quote
Old 04-18-2005, 10:55 PM   #5
ucfz31s13
But it still does nothing to correct the toe problem associated w/ lowering cars.
Old 04-19-2005, 09:49 AM   #6
importnut
importnut's Avatar
importnut is an unknown quantity at this point
I think it's a half-arse way to do correct camber. As for toe, that's corrected by adjusting the tie rod ends. The only way to do it right is to use an adjustable upper plate...which may not work with stock type suspension upgrades (confirm?)
Personally, I wouldn't bother with the Eibach part. They don't have a way to adjust the rears.
-Alex S.
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 04-19-2005, 09:59 AM   #7
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Sure. It works fine.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
