Old 04-18-2005, 11:31 PM   #1
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
Angry oil nut stripped!
well this isnt for my car but for my gf integra. really no need to post this on a honda forum since a oil pan is a oil pan is a oil pan.
well she took her car to a oil change shop since i wasnt able to do it due to school. well her car recently needed an oil change and i did it for her. well it turns out i believe the guy used a air gun to tighten the bolt. why to i believe this? because it hard 3x harder to take out than usual.
well when i took out the nut, it turns out the nut ITSELF isnt stripped but the OIL pan where you screw the nut into is stripped. it is stripped well becuz when i put the nut back in it keeps spinning.
so im asking is there any way to fix this besides putting a whole new oil pan in? 95blue told me i can get an oversize nut and restrip it myself? anybody know more insight on this? need help asap
SilviaDriver is offline   Reply With Quote
Old 04-18-2005, 11:47 PM   #2
aznpoopy
aznpoopy's Avatar
wow. that is retarded.
i'm no expert but i would guess the only thing you can do is rethread it for a bigger bolt or just swap the oil pan.
Old 04-18-2005, 11:59 PM   #3
nissan_driver24
nissan_driver24's Avatar
nissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enough
Send a message via AIM to nissan_driver24
u're best bet.... is a new oil pan.... u can retap it and put a bigger drain plug, but what if fails?? there is a chance u can ruin the engine.... better safe than sorry....
--240sx Driver Since 2002 to 2013--
nissan_driver24 is offline   Reply With Quote
Old 04-19-2005, 12:18 AM   #4
SilviaDriver
its kool, i found the answer. dont have the time/money for a new oil pan, barely any time to even do my oil change. im gonna go with a bigger drain plug, its been done and works. if i have to replace the oversize plug twice, then gonna change the pan itself.
thanks guys.
close thread
Old 04-19-2005, 10:07 AM   #5
SirWarrior
SirWarrior is an unknown quantity at this point
my Greddy has an oversized drain plug :P
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 04-19-2005, 08:35 PM   #6
s14sILV
s14sILV is an unknown quantity at this point
check up on it a few times. we all know what happens when your low on oil.
s14sILV is offline   Reply With Quote
Old 04-19-2005, 08:42 PM   #7
Ritz S14
Ritz S14's Avatar
I remember going to Ace hardware back in the day, and they said you can use some type of epoxy to retain the use of the same size drain plug.
The epoxy will fill the gap which has been stripped, and shape itself to the pitch of the drain plug. Let it cure, and it should be as good as new.
You can also helicoil it like so:
http://www.atvconnection.com/editor/.../techtip21.htm
Ritz S14 is offline   Reply With Quote
Old 04-19-2005, 08:54 PM   #8
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
my vote is for helicoil, i used it on my gsx-r oil pan, same thing happened.
speeddreamz is offline   Reply With Quote
Old 04-19-2005, 09:01 PM   #9
SilviaDriver
its kool, turns out the fuck who fucked it up already replaced it iwth a single oversize bolt!! so i decided to just put the nut back on and seal it with rubber sealant and gonna replace the oil pan this friday
Old 04-19-2005, 09:32 PM   #10
aznpoopy
aznpoopy's Avatar
wow... yeah, never go back to that shop!
so shady.
Old 04-19-2005, 09:45 PM   #11
sdtouge
sdtouge can only hope to improve
can you weld? is you can just drill it out, and weld in a new bung and screw for it, maybe a o2 sensor bung and just use and old o2 sensor... you get the idea.
or just drill it out and go with a slightly over size screw, but make shure you get a tap for that srcew/size/ thread pattern whatever to make threads so the screw will go in/out.
sdtouge is offline   Reply With Quote
Old 04-20-2005, 10:50 AM   #12
Rusker
Rusker's Avatar
Rusker is on a distinguished road
Welding? Epoxy? Oversized Nuts?
Just replace the oilpan. It's a HUGE pain in the ass, but if any of the above fails on your GF's car, the motor is toast. I just couldn't handle the constant checking of the oilpan to see if it's still holding up. Just do it right the first time...
Make the shop pay to have it redone at honda.
1990 S13/SR20
Rusker is offline   Reply With Quote
