Old 04-18-2005, 03:42 PM   #1
grndzro26
grndzro26's Avatar
grndzro26 is an unknown quantity at this point
Z32 Master Cylinder Question
I have a Z32 master cylinder and i need to know if the hole in the red circle needs to be plugged?
grndzro26 is offline   Reply With Quote
Old 04-18-2005, 05:31 PM   #2
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
I believe it does need to be plugged... Thats weird mine doesnt have that one... or maybe i didnt notice it.
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 04-18-2005, 05:50 PM   #3
mr_240sx
mr_240sx's Avatar
what did you pic up the MC for??
mr_240sx is offline   Reply With Quote
Old 04-18-2005, 06:25 PM   #4
grndzro26
grndzro26's Avatar
I have Z32 brakes on all 4 corners and i'm still running the stock 240 MC. I got the Z32 MC to complete the swap.
Old 04-18-2005, 08:50 PM   #5
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
plug it up
Jung918 is offline   Reply With Quote
Old 04-18-2005, 09:46 PM   #6
vinhisbored
vinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enough
Send a message via AIM to vinhisbored
If anyone's already done the master cylinder swap in their 240, and with 300zx brakes, can someone tell me if they feel better (when stopping). I have the 300zx brakes, but no z32 master cylinder yet due to money.
vinhisbored is offline   Reply With Quote
Old 04-18-2005, 09:52 PM   #7
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
^^^yeah they feel how they are suppose to.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 04-19-2005, 12:01 AM   #8
grndzro26
grndzro26's Avatar
Ok the question now is how to plug it? Should I thread it with a tap and plug it with a set screw? or is there a more easy way?
Old 04-19-2005, 09:35 AM   #9
importnut
importnut's Avatar
importnut is an unknown quantity at this point
That's a very odd hole. My MC didn't have it:
Z32 MC info
I say, tap the hole, use some thread sealant and a screw. Or thread lock.
As for the feel, it's awesome. I did all 4 corners first, and the pedal was super soft. Very unsettling. I just pulled the cover off of my 240 and drove it last night. I had installed some Porterfield pads up front, last fall, and never really got a chance to try them out before I put the car up for the winter. After seating the pads a bit, I was stunned by how powerful the brakes were and the feel of the pedal. The Hawk HPS pads I had before just sucked in a huge way.
-Alex S.
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 04-19-2005, 11:21 AM   #10
grndzro26
grndzro26's Avatar
It's a 1' Tokico. When i got the MC I checked to make sure it was on your list. Your website is great. I used it through out my whole brake swap.
Old 04-19-2005, 11:41 AM   #11
importnut
importnut's Avatar
Glad I could help!
Do you know if oil comes out of that little hole? Try bench bleeding and see what happens. I should have asked this earlier
-Alex S.
Old 04-19-2005, 12:55 PM   #12
getsideways77
getsideways77's Avatar
getsideways77 is an unknown quantity at this point
Drill and tap it i dont know if this has been covered do all the lines thread properly?
getsideways77 is offline   Reply With Quote
Old 04-19-2005, 12:56 PM   #13
getsideways77
what did you do for the emergency brake did you get the 300zx backing plate and the shoes springs and star wheel adjuster
Old 04-19-2005, 02:56 PM   #14
grndzro26
grndzro26's Avatar
importnut- how do you bench bleed it?
get sideways - i got the whole e-brake assembly and used z32 cables. I routed the cables through a hole in the subframe. it looks like it was meant to be there
Old 04-21-2005, 10:29 AM   #15
getsideways77
yeah from where im thinking about ordering it from nissan from my school cause i cant find any z32 junkers
Old 04-21-2005, 10:51 AM   #16
importnut
importnut's Avatar
Well, I just put mine in a vice and ran some fluid through it. I know some people will make short lines that are attached where they are supposed to go, then run them into the reservoir. Then, pump the MC to get the bubbles out. I just set it up, and let the fluid run through it. I don't know if it really helps or not, but in your case, you can at least see if fluid comes out of that hole.
-Alex S.
Old 04-21-2005, 10:54 AM   #17
importnut
importnut's Avatar
rear brake swap
You'll need everything. If you can, just pick up a complete rear knucle assembly. Unless you use shocks with interchangeable lower mounts, you cannot use the aluminum upright. So, you'll have to transfer everything over to the stock upright. Check out my site for the details.
I'm hoping...soon...to get some stock 240 e-brake cables so I can make calbes that work right. I will definitely post that info once i have it ready.
-Alex S.
Old 04-21-2005, 01:01 PM   #18
FRpilot
FRpilot's Avatar
it looks like the hole where the screw is loosened to rebuild the pistons in the mc. but i think that screw was on the other side. maybe its over there for the tokico mc.
FRpilot is offline   Reply With Quote
Old 11-11-2005, 02:18 AM   #19
jy116
jy116's Avatar
jy116 is making a name for him/her selfjy116 is making a name for him/her self
kinda not related, but since sumone else asked about feel.... hows the power of ur ebrake feel? I mean, if u ever try using it to initiate a drift, u think the old disk ebrake locked better for drifting [vs z32 drum ebrake]?
Thanks for wutever feedback :]
KYB AGX w/ dust boots $500obo... sadly serious
jy116 is offline   Reply With Quote
