Old 04-20-2005, 11:47 AM   #1
nokuntrol
nokuntrol's Avatar
nokuntrol is an unknown quantity at this point
Send a message via AIM to nokuntrol
Tie Rod End Links + Stock tie rods?
Does it make a big difference if you use the stock tie rod, but with adjustable tie rod ends?
nokuntrol is offline   Reply With Quote
Old 04-20-2005, 12:32 PM   #2
raen419
raen419 is an unknown quantity at this point
Send a message via AIM to raen419
tie rods are adjustable to begin with.
if you're talking about a performance one (tein, even though it's not really a performance end, just s14 oem basically) then no.
most tie rods ends require an aftermarket inner tie rod.
raen419 is offline   Reply With Quote
Old 04-20-2005, 11:26 PM   #3
Cthulhu
Cthulhu's Avatar
Cthulhu is an unknown quantity at this point
Send a message via AIM to Cthulhu
If you're using a kazama/kts or other adjustable tie rod ends, you can adjust for bumpsteer. That's something.
Cthulhu is offline   Reply With Quote
Old 04-20-2005, 11:28 PM   #4
Dousan_PG
Dousan_PG's Avatar
yep
i have smoe SPLParts.com tie rod ends coming this week or early next should be here
good for lowered cars
adj away that nasty bumpsteer, its not so fun.
right now i hvae tien rods (inner and outer) works but with the car lowered its not fun sometmes on freeways and espeically in bad weather on the road
Aaron
Pink GodziRa
Old 04-20-2005, 11:47 PM   #5
raging panda
raging panda is an unknown quantity at this point
Send a message via Yahoo to raging panda
whats the opinion on stock inner tie rods? Will they hold up with a aftermarket outter? Or should both probably be upgraded?
raging panda is offline   Reply With Quote
Old 04-20-2005, 11:52 PM   #6
Dousan_PG
Dousan_PG's Avatar
depends
stock inners like s14 would be a worthy upgrade over s13
now rmemeber depends on end too
compare kazama and nams
tell me which is beefier by looks: NAMS
i couldnt say which is REALLY beter but the NAMS definately looks to be.
i was going nams but kuah at spl said the spl ones have more adjustment [then nams/kazama] so thats why i went with those..and cheaper. car is pretty low..
i havent looked at the spl ones, im sure they are closer to nams, i talked w/ kuah about nams vs kazama sometime back waybefore his version came out.
the weakest part of the tie rod/end setup might be the threaded part, a beefy rod that goes into a small thread part is useless. beefiness all across is key
and z32 fits s13/s14
just hve to use both inner and outer
kazama:
NAMS:
SPLparts.com
Aaron
Pink GodziRa
Old 04-21-2005, 06:47 AM   #7
Johny5
Johny5's Avatar
see i always thought that nam's would do better bumpsteer adjustment due to the angle of the end of the tie rod, that PLUS the heigh adjustability with spacers. oh well i feel like a poser anyways now, i went with cheesesauce kazamas.
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 04-21-2005, 11:01 AM   #8
raging panda
the spl requires the z32 inners right? That looks like a pretty good upgrade, but you can also use s14 inners and S14 outters on a S13? No mods? If its that much of a difference i might go for some s14 inners on a parted out s14 with some aftermarket outters. Or if i find some z32 for a good price ill go with the spl maybe.
Old 04-21-2005, 11:19 AM   #9
Dousan_PG
Dousan_PG's Avatar
no they dont they make both versions
i got the s14 version i dont use inner z, i use tein tie rods
my friend does so he got the spl z ends
Aaron
Pink GodziRa
Old 04-21-2005, 11:23 AM   #10
Cthulhu
Cthulhu's Avatar
you and me both, and I can actually buy the NAMS here if I wanted.
protip: NAMS and Ikeya formula are by no means identical, but look very similar in design (angled end etc.). NAMS are ~$230 retail here, vs over 300 for Ikeya.
Old 04-21-2005, 12:39 PM   #11
Salty_X
Salty_X is an unknown quantity at this point
I can't really visualize how the angle on the Nams helps lessen the tie rod angle, someone care to educate?
I went with cheesesauce kts.
Salty_X is offline   Reply With Quote
Old 04-21-2005, 07:17 PM   #12
Johny5
Johny5's Avatar
WORD
CHEESESAUCE, RED, BLUE, SUPER CHEESESAUCE POWERS COMBINE INTO JDM MULTILINK!
haha damnit i still want your flcas :whackit:!!!
