Old 03-19-2002, 12:55 PM   #1
BlackFox
BlackFox is an unknown quantity at this point
Hey there, as you probably know I made a deal for a 95 240sx se for $6300, I'll be getting it when I sell my 89 celica.
anyways, when I took the 240 onto the freeway, the steering wheel vibrates back and forth, when i got faster than 65 the vibrations get closer together, and the steering wheel doesn't align straight. My question is... does the car just need a wheel alignment?
Current Cars:
1976 Mercedes Benz 300D
1995 240sx SE aka Kate (winner: Best Stock S14 @ 2002 National Convention)
http://community.webshots.com/user/jeff976cal
If you're interested in parts email me
[email protected]
BlackFox is offline   Reply With Quote
Old 03-19-2002, 02:43 PM   #2
geeaj
geeaj is an unknown quantity at this point
Most likely a bent rim or your wheels/tires need a high speed balance. This is a notorious problem with s13. The wheel vibrates at 65mph, disappearing as speeds decrease or increase.
I got rid of my "most" of my wobble by replacing tie rod ends, tension rods, and alignment. These are other areas which may cause this wobble. But I would check your wheels firsts, see if they are bent. If so, swap and test drive again.
Good luck.
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
Old 03-19-2002, 03:31 PM   #3
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
mine does the same damn thing at 65.. once i'm going 75 it's smooth.. and anythign under 63ish it's smooth... i have an s14 tho..
__________
96 s14
300zx lsd
zeal b2's
AJ is offline   Reply With Quote
Old 03-19-2002, 04:01 PM   #4
Arcane
Arcane is an unknown quantity at this point
you probably threw one of the lead weights...you might need to get your wheels balanced...i was experiencing the same problem last weekend...got my wheels balanced and it's all better...
it's called a life...maybe you should get one!!!
Arcane is offline   Reply With Quote
Old 03-19-2002, 04:23 PM   #5
Red
Red's Avatar
Red is an unknown quantity at this point
Just get a Ballance and alignment that should fix your problem it did mine. &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 03-19-2002, 05:07 PM   #6
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
yea mines doing that too , but at 55MPH
damn it
91CRXsiR is offline   Reply With Quote
Old 03-19-2002, 05:13 PM   #7
Red
Red's Avatar
Mine did it for a month, But I took it in and poof it was gone now i'm good from 0-119 <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> Man I needa new cpu
Old 03-19-2002, 05:27 PM   #8
Danio
Danio is an unknown quantity at this point
I had the same problem. After the tires got rebalanced the problem disappeared.
DKwan.com
Danio is offline   Reply With Quote
