Old 05-16-2005, 08:33 PM   #1
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
Totally glazed over my rotors! Now what?
OK I've posted this problem about my ebrake never working right, it won't lock the rears, it takes 10+ seconds to fully lock, etc, etc.
I took it over a friends house to have the ebrake cables swapped out, he takes off the wheel, and says "Ummm I don't think your ebrake is the problem, your rear rotors are totally glazed over".
I'm running cross-drilled and slotted Brembo rotors front and rear, Project Mu Type NS front pads and Mu D1 Spec rear pads.
Now I'm not sure what to do at this point. Do I need all new rotors and pads? Or just rotors?
Why the hell would my rear rotors be completely glazed over if I'm using street brake pads? I thought that only happened with crappy pads.
And whats the best way to avoid this happening again? I have no idea how the hell my rotors got like this to begin with.
JaeTea is offline   Reply With Quote
Old 05-16-2005, 08:38 PM   #2
TheTimanator
TheTimanator's Avatar
Get them turned/cut? I'd at least try that before you go spending the money on new rotors. Also, did your friend check the pads to make sure they weren't glazed over as well?
were the rotors zinc coated? did you let let the pads break? I've heard stories of people having problems with the coated rotors but don't know how true they are.
Old 05-16-2005, 08:48 PM   #3
FRpilot
FRpilot's Avatar
maybe its the rotors? get blanks and try that out.
FRpilot is offline   Reply With Quote
Old 05-16-2005, 09:43 PM   #4
MovinUp-1
MovinUp-1 is an unknown quantity at this point
Make sure that your e-brake is disengaging completely. You could glaze the rotors if you just drove around for a little while with the e-brake engaged.
Allen
Delta Region SCCA
SM 1990 240SX SR20DET
MovinUp-1 is offline   Reply With Quote
Old 05-16-2005, 09:56 PM   #5
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
have them turned with a non-directional lathe, can help prevent it.
If you want to try it, a die grinder and an aggressive scotch pad (I think the correct name) can be used to deglaze and give them a non-directional finish.
krustindumm is offline   Reply With Quote
Old 05-16-2005, 09:58 PM   #6
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
Scuff up the rotor with sand paper and see what happens
Slide Happy
chuy is offline   Reply With Quote
Old 05-16-2005, 10:24 PM   #7
JaeTea
JaeTea's Avatar
They were zinc coated and you can't turn/cut slotted-cross drilled rotors.
Not sure if the pads were glazed but I'm buying new ones.
Old 05-16-2005, 11:07 PM   #8
Raysurc
Raysurc can only hope to improve
Send a message via AIM to Raysurc
what does glazed rotors mean? what does it do?
Raysurc is offline   Reply With Quote
Old 05-16-2005, 11:29 PM   #9
Prep Guy
Prep Guy is an unknown quantity at this point
if you get chemicals on your rotors like grease and the friction makes it all blinged. your rotors and ur pads become slippy so friction is limited so your brakes arnt griping.
are you leaking anything in that area?
Prep Guy is offline   Reply With Quote
Old 05-17-2005, 05:24 AM   #10
JaeTea
JaeTea's Avatar
Nope.
Somehow the rotors got glazed within a few days after installing my pads and rotors because my ebrake never worked since then
Old 05-19-2005, 10:04 PM   #11
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Did you use the brake cleaner before you installed the rotors? They have a coating from the factory so they won't rust while in the store.
Pacman is offline   Reply With Quote
