Old 05-20-2005, 07:47 PM   #1
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
rear ball joint - spinnage factor
Ok, how do you tighten the nut that holds the knuckle on the ball joint. Mine spins and i can't figure out how to make it not do that. Now im using the old rusted nut which kind of doesn't want to go on too well and puts a fair amount of resistance at times....
do i have to get a new nut for that one? or is there a trick to do this. Book doesn't seem to go in detail much
Thanks for any help
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 05-20-2005, 10:51 PM   #2
projectRDM
projectRDM's Avatar
If it's spinning then either the nut or the threads on the balljoint are damaged. If it's the nut, replace it, if it's the balljoint then you're fucked.
I've got spare Aarms if you need one.
FORMERLY R240NA
Old 05-21-2005, 08:24 AM   #3
Kreator
Kreator's Avatar
hmmm... i think it's just rust on the nut. the car is a 97, and its the same behavior on both
well i guess i'll mess some more with it today, and if nothing helps ill pm ya
