Old 06-03-2005, 07:58 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
sr20det backfire flames
hey guys, what causes backfires basically? letting off the throttle after getting on it & running rich?
My car shoots flames randomly, i'd like to be able to control them without getting a cat, hence be able to shoot the fire whenever i feel like it and not shoot fire when a cop is around..
I did do a search but all the people talked about were homemade exhaust flame shooters and crap..
I like the flames
sepulchral is offline   Reply With Quote
Old 06-03-2005, 08:05 PM   #2
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
Just get the rev limiter to cutoff ignition when rpm gets to the top, so the extra fuel will maske u pop flame. And tune ur car with a basic safc. so it will not run rich when you drive normal and backfire when you don't want it to. better mileage too
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline   Reply With Quote
Old 06-03-2005, 08:07 PM   #3
sepulchral
the Bee R rev limiter would be nice i guess
Old 06-04-2005, 12:09 PM   #4
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Go 115 in 4th
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 06-04-2005, 04:45 PM   #5
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
The cause is based upon heat development of the system itself. When you have warmed the turbine up to a likely temperature, then go on to run closer to the red points on the speedometer, you will experience backfire, this occurs when letting off the throttle at that point.usually during highpoints of back pressure within the exhaust system, 3rd -4th gears. The Bee-R system simply allows you to control where that cut-off will be, 6200, 5800, etc etc. Even upon tuning the engine, incorporating a stright pipe will only excelerate the probability of backfire. increased fuel injection, and air intake. You're still going to get Unused gasoline coming thru that stright pipe.
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 06-05-2005, 08:20 PM   #6
JDMs13
JDMs13 is an unknown quantity at this point
Send a message via MSN to JDMs13
Bee-R is just what your looking for.
JDMs13 is offline   Reply With Quote
Old 06-06-2005, 10:05 AM   #7
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
Guys he's NOT looking for BEE-r. READ THE FUCKIN POST> He says his car shoots flames randomly . What you need is tuning. My car doesnt shoot flames. Mine's ECU. More advance timing= more time for fuel to burn. Timing naturally retards when you go off throttle, cause more unburned fuel to get past the engine and ignite in the exhaust system.
The only way the Bee-r with help shoot flames is if you hit the rev limiter. THen you'll have ignition cut with no fuel cut.
Hi
Var is offline   Reply With Quote
Old 06-06-2005, 10:12 AM   #8
JDMs13
If you read his post, he wants to be able to shoot flames on command. Not whenever his car blows off. A bee-R is a sure fire way to shoot flames on command.
Greg
Old 06-06-2005, 10:29 AM   #9
sepulchral
both of you all are right, i do need tuning because i dont want to run rich that im shooting flames at random but the beeR rev limiter would be nice because it would cut ignition rather than fuel = much safer condition for motor however i know the turbo does suffer some, but who cares turbos dont last forever, especially at 14psi daily (my old car ran 14psi daily for a year (22k miles) until it started making funny noises)
