Old 06-13-2005, 08:25 AM   #1
luvsr20
luvsr20's Avatar
luvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to behold
Send a message via AIM to luvsr20
KA Transmission Problems
Here's my problem, the past couple of days ive been driving my car there has been alot of funny business going on with my trans. Its goes into first gear fine, when i goto move forward as i let off the clutch and begin to press the gas it starts grinding. i cant even relase the clutch to the point where the car will start rolling by itself becasue it will just grind. As im driving and shifting the it goes into 2nd,3rd,4th fine @ 3k rpm anything higher as in 3500-4000 rpm it might grind. Once i get to 5th and i shift the kind-of grinds, when i shift into 5th but press and hold clutch in then shift it goes into 5th fine. I have a spec stage 2 clutch, b&m short throw, and the fluid in the trans is just what nissan recommends. I just need help thanks
luvsr20 is offline   Reply With Quote
Old 06-18-2005, 09:37 AM   #2
luvsr20
luvsr20's Avatar
i need a new clutch, but my question is, what's going to be the major differecne between having a stock clutch with a lightweight flywheel vs. a upgraded clucth with a lightweight flywheel?
