Old 06-14-2005, 10:56 PM   #1
o5i2
o5i2 is an unknown quantity at this point
Send a message via AIM to o5i2
weird ticking/rattling sounds comming from the transmission???
i have recently noticed a ticking/rattling sounds comming from around the transmission/block area. i only hear it when i press on the gas when in gear. in neutral or while rolling, it is normal. im thinking its the transmission? im in the middle of a short shifter install, so i took off the boots and such, and drove around, the sound is louder and i think i hear the sound comming from the tranny. i'll see if i can get a sound clip later on in the week.
anyone have a similar problem or know whats going on?
o5i2 is offline   Reply With Quote
Old 06-14-2005, 11:18 PM   #2
kandyflip445
kandyflip445's Avatar
What gear? Auto or stick?
My 240 vBgarage
Old 06-15-2005, 02:24 AM   #3
o5i2
all gears, on a manuel transmission
Old 06-15-2005, 02:27 AM   #4
aznpoopy
aznpoopy's Avatar
i bet you have a loose heatshield.
another culprit may be the bracket that extends from the tranny mount to the exhaust. mine rusted right down the middle, and the metal ends would touch each other during driving and making a scraping rattling metal noise.
get under the car and check it out.
Old 06-15-2005, 02:29 AM   #5
kandyflip445
Yeah. The exhaust ground rust off and hits the exhaust too.
My 240 vBgarage
Old 06-15-2005, 02:52 AM   #6
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
hehe, i had a sound like that the other day. I looked under the car and what do I see? Four missing bolts on the cat. Barly hanging on by the studs. After a rebolt, the sound went away.
driftingisgay.com
nrg is offline   Reply With Quote
Old 06-15-2005, 02:58 AM   #7
aznpoopy
aznpoopy's Avatar
ah.. the joy of owning a 240sx. can't beat it.
Old 06-15-2005, 02:37 PM   #8
o5i2
thanks guys, all your responses sound very likey as i have installed a catback recently. i could have swore it was comming from around the tranny area tho, but then i guess they are in the same vacinity. anyway, i'll go under the car and check it out. thanks for all your help.
