Old 06-25-2005, 10:56 PM   #1
publicenemy137
publicenemy137's Avatar
publicenemy137 is an unknown quantity at this point
Send a message via AIM to publicenemy137
D2 owners! Need help! How big are the springs?
Well I have a steering clunk, I think it's from the springs rubbing on each other. Going to get these:
Silence Noisy Coils
Use Whiteline's new spiral coil wrap to silence noisy progressive coil springs. Most new cars use coil spring insulators to reduce NVH resulting from coil bind or contact between "dead" or closed coils. Many aftermarket springs require a progressive design using "dead" coils to meet captive height design requirements. These can become noisy under certain loads making an add-on insulator very useful.
The spiral design lets you insulate the springs WHILE the coils are in the vehicle saving time and money. Each pack contains 1.5 metres of heavy duty plastic spiral wrap which is enough to do 2 springs.
There are two options:
Whiteline K60950 10-13mm Black Coil Spring Silencers . . . . . $9.00/package
Whiteline K60951 13-18mm Yellow Coil Spring Silencers . . . . . $12.00/package
Do I get the 10-13 mm or the 13-18 mm ones?
http://www.pdm-racing.com/products/suspension.html
check out my 240sx in my cardomain page
1
CLICK HERE TO SEE MY CARDOMAIN!
help me decide my next set of rims
publicenemy137 is offline   Reply With Quote
Old 06-26-2005, 12:22 AM   #2
s13driver
s13driver is an unknown quantity at this point
why don't you email them and ask what's the difference between the two ?
it is so hard to educate the uneducated.
s13driver is offline   Reply With Quote
Old 06-26-2005, 03:05 AM   #3
ma71supraturbo
ma71supraturbo is an unknown quantity at this point
Send a message via AIM to ma71supraturbo
I'll check for you on monday
ma71supraturbo is offline   Reply With Quote
Old 06-26-2005, 10:04 AM   #4
publicenemy137
thanks supraturbo. And s13driver, b/c that's at PDM racing, not D2's site. D2 people speak only taiwanese, so I wouldn't be able to ask them.
1
Old 06-26-2005, 10:29 AM   #5
Project D
Project D is an unknown quantity at this point
Send a message via AIM to Project D
wow, this looks like a neat item which just may be crazy enough to work. Interested to see which ones to get. (Black would be great since the coils are black!!)
Project D is offline   Reply With Quote
Old 06-26-2005, 11:47 AM   #6
publicenemy137
yeah it does look pretty neat and interesting. I'm also looking into other silencers but not coming across any yet. I heard Tein has some but didn't find any on their website
1
Old 06-26-2005, 12:46 PM   #7
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
before you assume its your coilovers (like I did with my d2's) take a look at your tie rods. Mine were so shot it was ridiculous. I replaced them with tein tie rods and all the noise went away. Also,check your steering rack bushings- Rob
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 06-26-2005, 02:28 PM   #8
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
As well as tension rod bushings. Also try greasing the upper mounts, it helped on mine(D2), What spring rates do you have?
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 06-26-2005, 09:36 PM   #9
publicenemy137
7/5. I'll try greasing the upper mounts. The t/c rod bushings are fine
1
Old 06-26-2005, 09:37 PM   #10
publicenemy137
did yours just make noise when driving or only when you were turning the steering wheel?
1
Old 06-27-2005, 10:53 AM   #11
publicenemy137
I already replaced my tie rods with Tein Tie rods as well. steering rack bushings and all other bushings are fine. Can tell the noise is coming from the springs
1
Old 06-27-2005, 10:59 AM   #12
sr240mike
I got this directly from that page, this is what it says about the top insulator.
"Does your front end pop, clunk and make grinding noises when you turn the wheels. When you are backing up out of your driveway, do you hear a violent metallic “POP” noise? Replaced your TC Rod bushings and still hear a clunk up front? Chances are, your top spring perch bearings are gone, and you are hearing the clunk of the bearing or the spring actually releasing as it winds itself up due to the bearing not allowing the spring and suspension to rotate through the 240SX’s proper swing. Dirt, grit, water all attack this actual bearing inside the mount and we see this situation time and time again on cars that come through our shop. Solution, change the entire unit today with an OEM top spring bearing mount insulator. This unit is a bearing mounted inside of metal cup that is surrounded by rubber to help isolate road noise, vibration and allow deflection of the spring assembly as your car’s suspension is turned and twisted. Over time, the bearing is attacked by water, grime and dirt, and the rubber breaks down from heat, salt and freezing. If the bearing seizes, it will not allow the shock assembly to rotate smoothly, and binds the spring "
Now obviously you can't use them since you have camber plates, but greasing/cleaning them might help.
Old 06-27-2005, 11:50 AM   #13
ma71supraturbo
D2 says they are 1/4" which would be ~ 7mm
Old 06-27-2005, 12:53 PM   #14
publicenemy137
damn. so that means it's too small for both options huh. Anyone know where I can get a 7 mm coil silencer? I've looked around, only found the ones above. I heard Tein sells some but I couldn't find em.
1
Old 06-27-2005, 06:33 PM   #15
sr240mike
1/4" no way!!!!!!!!!!!! Thats way too small. I'll go get my calipers out right now. K, fronts are 11mm.
Old 06-27-2005, 08:14 PM   #16
publicenemy137
thanks sr240mike, ordering the coil silencers now
1
Old 06-28-2005, 09:25 AM   #17
ma71supraturbo
Sweet, thanks mike. And let us know how they work Publicenemy -- Im curious
Old 06-28-2005, 11:02 AM   #18
publicenemy137
will do. Ordered a set from PDM last night. Not sure how long they will take to ship since it's from Jaahhhhpan! I'm also goin to take mike's advice and grease up the upper mounts this thursday, to see if that takes away from the steering grind
1
