Old 06-28-2005, 10:43 PM   #1
Ritz S14
Ritz S14's Avatar
Turbo timer harness question
So I bought a TT harness off of ebay. It plugs right into my Greddy TT. But it wont start my car, with the harness removed and factory plugs are plugged back in, it starts. The turbo timer does work, with the key off, it remains running.
I'd take pictures of it, but batteries are dead.
Anyone with a pic of a 240sx TT harness? I just want to see where the wires are routed, or which wires are missing.
Thanks in advance.
Edit: Also, the plug I plugged it was inside the steering columb. Since there wasn't any plugs underneath the dash. This harness is susposed to be for a clean install, and be idiot proof.
Ritz S14 is offline   Reply With Quote
Old 06-28-2005, 10:53 PM   #2
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
It should only route 3 wires into the TT. I think they are red yellow and black, but thats a wild guess, its been a while.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 06-28-2005, 10:55 PM   #3
Ritz S14
Ritz S14's Avatar
TT works fine. They just F'd up the starter input part.
Old 06-29-2005, 10:09 AM   #4
Ritz S14
Ritz S14's Avatar
Okay, with some help, I found the problem.
The s13 TT harness, will plug into an S14 harness. In order to make it work, you need to add a wire to S13 TT harness.
I added the red one
I lent my digi cam to someone, so I'm stuck with a crapcam.
Old 06-29-2005, 04:59 PM   #5
Ritz S14
Ritz S14's Avatar
ANOTHER QUESTION!!! Why is that, if I turn the key off from "RUN" to "ACC" the car doesn't stay on, then when I completely turn the key off, the turbo timer kicks on?
The turbo timer is only effective when I quickly turn the car off from "RUN" to "off". Anyone?
Old 06-29-2005, 07:00 PM   #6
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Switch the wires around.
-Jeff
Whatup?
Old 06-30-2005, 10:43 AM   #7
projectRDM
projectRDM's Avatar
JDM cars do not have the 'hot start' wire in the ignition harness. Therefore any plug in harness will only have five wires total, not six like US cars. You have to add the additional wire like you found out.
FORMERLY R240NA
Old 06-30-2005, 10:46 AM   #8
Ritz S14
Ritz S14's Avatar
Cool, how about having the turbo timer kick on while I switch from "run" to "acc", instead of Run->off?
Thanks guys.
Ah thanks Jeff works great
