Old 06-17-2005, 09:54 PM   #1
samms95s14se
samms95s14se's Avatar
samms95s14se will become famous soon enoughsamms95s14se will become famous soon enoughsamms95s14se will become famous soon enoughsamms95s14se will become famous soon enough
Master Guide For Buying Wheels!!
This thread is for people to BREAKDOWN exactly what Tire and Wheel combination they have? But this will be different than most other posts.... you'll see what I mean in a moment....
Now i've looked at many many threads on wheels, tires, rims, and suspension pictures and so on but there is not one that will have it all or what I need, for EXAMPLE... I'll see a post where someone says they have an S14 with 17" but no offset given? or 17" with offset but no tire size? or 17" with offset and tire size but no picture? or 17" with offset, tire size and picture! but not the right angle on the picture to see how flush or stretched or whatever and no suspension setup. See what I mean!!
Also I started thinking that this thread can actually answer a lot of questions I never thought could be answered like you've seen these ones ..... "What coilovers are everyone using" and "Best Rucas, Tie rods, and so on to use" WELL DUH! If there are so many pages and pictures of what people are using what do you think could be the most popular to use? You could almost build stats out of it for fun?
Also if you have posted in here in the past and have a new setup add on to this with your new specs! And you get to whore out some pics too. Just trying to help control new threads and PM sent questions.
So here is a formula to follow to help people get the real perspective on wheels so if you could post all of this information using the numbers given or whatever you can fill in, but try to add it back in later when you have time. Good luck trying its alot!! But should help people from searching hundreds of threads that take up all your time to read through. NEW QUESTIONS ADDED.
1. S13/S14/S15 =
2. Suspension Setup/Brands =
3. Wheel/Rim Size front & back =
4. Brand of Wheel/Rim =
5. Offset front & back =
6. Spacer Size =
7. Tire Size/Brand front & back =
8. Alignment Specs =
9. Clear Zbrakes & what size brakes =
10. Fender Modifications: rolled/pulled =
11. Picture.. from the side & down the side =
12. Over Fenders Brand & mm Size =
13. Tire Pressure front & rear Track/Daily Driving =
14. Lip size front & Back =
Thanks everyone! THIS could be the Master Guide?
Also should be a STICKY ?? If you think about it.
Last edited by samms95s14se; 03-15-2009 at 03:28 AM.. Reason: New questions added to the list
samms95s14se is offline   Reply With Quote
Old 06-17-2005, 10:03 PM   #2
Dousan_PG
Dousan_PG's Avatar
sounds like a fun thread.
mods delete people who dont respond correctly
no "hey what" qs.
only pics to reply
make me a mod and i'll rule this thread w/ an iron fist
PM PEOPLE IF YOU HAVE A QUESTION
add number 7, alignment!!
and here's my beater..prekouki
1) s14 1995
2) too much, you only need to know Tanabe DD coilovers, -3 degrees camber
3) 17x9, 17x10 Desmond Regamaster
4) 9 +18, 10 +20
5) 215/45/17, 235/40/17
6) alignment at time pics taken: -2 camber front, -3 rear (changed now)
8) clears front and rear z32 brakes
9) rear fenders hammered about 10mm-15mm if that...fronts rolled (hammered now). setup also works perfect for 18x9.5 +12 (Work Emotion) with a 235/40/17
Aaron
Pink GodziRa
Old 06-17-2005, 10:10 PM   #3
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
8] clear zbrakes and what size brakes and if spacer needed
9] fender modifications: rolled/pulled how much
sorry sold all my wheels savin for VS-KFs
you can delete my post after you entered #8/9 in
SilviaDriver is offline   Reply With Quote
Old 06-19-2005, 01:25 PM   #4
samms95s14se
Wow! no one but Dousan PG has any specs and pictures! and by the way GREAT job on the info and NICE pics!!! thats how you do it. So everyone wants to continue to ask random wheel and tire fitment questions just to see people reply back SEARCH?? and go back and forth for ever????
Can we get some members who posted pics in the picture threads to help out on this? Remember you can edit back in information that you don't have right now later, just skip numbers if you have to.
Ok let's try this....One More Time!!
Old 06-19-2005, 02:21 PM   #5
ThatGuy
Admin Asshole
ThatGuy's Avatar
This won't get the coverage it needs being in the Tech Section. Moving it to Chat.
Old 06-19-2005, 02:38 PM   #6
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
1. S13/S14/S15 = S13 Hatch
2. Suspension Setup = Silk Road RM/A8
3. Wheel/Rim Size front & back = 15x7.5
4. Brand of Wheel/Rim = SSR Reverse Mesh
5. Offset front & back = +7
6. Spacer Size = none used
7. Tire Size front & back = 195/50/15
Front: 3.5 degrees camber/0 toe/7 degrees castor
Rear: A lot of camber (prolly 2.5-3)/0 toe
9. Clear Zbrakes & what size brakes = Have stock brakes, won't clear Zs
10. Fender Modifications: rolled/pulled = Rear fenders rolled slightly, but no need unless you run 60 profile tires
11. Picture.. from the side & down the side = Second pic, rear wheels are 16x8+32
4. Brand of Wheel/Rim = Riken Mesh
5. Offset front & back = +2
7. Tire Size front & back = 205/60/15
10. Fender Modifications: rolled/pulled = Rear fenders rolled slightly, but no need unless 60 series tires
11. Picture.. from the side & down the side = Only on front, can't find any pics of them all around
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 06-19-2005, 02:50 PM   #7
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
1. S13
2. flta2's
3. F 18x9 R18x9
4. Nissan ? BNR34 OEM
5. F +30 R +30
6. F 15mm R 15mm
7. F 225/40 st115 R 225/40 st115
8. F -3 camber, 7*caster R -2.2 camber
9. stock brakes
10. F rolled R rolled and pulled (about 5mm)
11.
ill get some new pictures soon, these will do for now
lilredstiffy is offline   Reply With Quote
Old 06-19-2005, 06:48 PM   #8
Flybert
1. S13
2. Apexi N1 PRO
3. 17x9 front and rear
4. Veilside Andrew
5. +17 front and rear
6. no spacer
7. 215/45/17 front and rear
8. -2 F, -2.4 R
9. Clears Z32
10. Just rolled with a hammer, now they are pulled in the rear and some fatter tires will go on
Old 06-19-2005, 08:21 PM   #9
Ritz S14
Ritz S14's Avatar
s14
MR C/O
17x9+15 225 45 17
17x10+12 245 45 17 Falken st115
5Zigen FN10RC
What ever you get from a 3" drop front, and 4" drop in rear.
26mm clear z brakes, these suckers will clear 50mm brakes
Rears are pulled .75"
Ritz S14 is offline   Reply With Quote
Old 06-19-2005, 08:47 PM   #10
p11driver
p11driver's Avatar
p11driver is an unknown quantity at this point
Send a message via AIM to p11driver
1. S14
2. Tanabe sustec pro
3. 17x9 , 17x9
4. ADVAN SA3R
5. +22 , +22
6. none
7. 235/40 , 245/40
8. camber -2 front, -2.5 rear
9. Clear any breaks
10. no roll or pull
p11driver is offline   Reply With Quote
Old 06-19-2005, 08:53 PM   #11
S14DriftR
S14DriftR's Avatar
S14DriftR is an unknown quantity at this point
Send a message via AIM to S14DriftR
1) s13 coupe
2) Tein HE
3) 16x7.5
4) Volk SF mesh
5) +22
6) 25mm kics bolt ons
7) 205/50/16F 225/50/16R(pictured, but normally 205/50's all 4)
8) -2.8f -2r
9)clears Zbrakes with spacers, does NOT clear Z brakes without the spacers
10) rear fenders pulled about 15mm, fronts rolled\
Rear with buldging 225/50's:
Front pics w/205/50/16's
S14DriftR is offline   Reply With Quote
Old 06-19-2005, 10:38 PM   #12
AKADriver
AKADriver's Avatar
My old white car...
1) S13 coupe
2) KYB AGX/RS*R Race/HKS pillowball mounts
3) 16x7.5
4) Kosei K1
5) ET32 front and rear
6) none
7) 225/50R16
8) always changing, cleared everything with every alignment setting I threw at it
9) clears EVERYTHING
10) stock bodywork
conservative setup. but I liked it a LOT. very versatile.
Old 06-20-2005, 01:57 AM   #13
BobbyBoy
BobbyBoy's Avatar
BobbyBoy is making a name for him/her selfBobbyBoy is making a name for him/her self
Send a message via AIM to BobbyBoy
1. S13
2. KTS Coils
3. F 18x8.5 R 18x9.5
4. Enkei NT03+M
5. Offset F +38 R +27
6. Spacer F +30 R +30 (new offsets F +8 R -3)
7. Tires F 225/35/18 (soon to be 245/35/18) R 275/40/18 (soon to be 275/35/18)
8. No alignment specs
9. Clears Z brakes
10. +15mm Front +50mm Rear
BobbyBoy is offline   Reply With Quote
Old 06-20-2005, 07:33 AM   #14
xVaporx
xVaporx is an unknown quantity at this point
1. S14
2. Tein FLEX coilovers, RUCA's, Rtoe arms
3. 18x9 F 18x10 R
4. Volk Racing SF Challenge
5. Offset front & back = +10, +11
6. I dont need no stinking spacer
7. 235/40/18 F 255/35/18 R AVS Sports (run a bit wider, like a 240/260)
8. -3 camber F, -2 camber rear
9. Z Tuner Z32 kit 12.3in rotors clears no spacer
10. Front +20mm over fenders, rears pulled ~25mm
xVaporx is offline   Reply With Quote
Old 06-20-2005, 10:55 AM   #15
orion::S14
orion::S14's Avatar
1. S14
2. Tein HE (reasonably low, not "slammed")
3. 17x9 (all 4)
4. Enkei RPM2
5. Offset +40
6. 15mm spacer at all 4 corners (effectively +25 offset)
7. 235/45/17 (F), 255/40/17 (R) Kumho MX
8. -2.5 camber (F), -1.8 camber (R)
9. Z32 brakes (all 4 corners, wheel clear with or without the spacers)
10. Front fender untouched, rears *barely* rolled.
11. No good pics of the height/clearance, but here goes anyway:
- Brian
www.KA24DEvelopment.com
Old 06-20-2005, 11:11 AM   #16
biggie
biggie is an unknown quantity at this point
Send a message via AIM to biggie
Will be getting new wheels on soon (trying to sell new 17x8 FNs), but here are these for reference.
1. S13
2. D2 Coils (9/7 rates), pretty low
3. 17x7
4. Lenso Superlight (out of production)
5. +38 Offset
6. 5mm spacer all around
7. 215/45/17 Toyo Proxes FZ4s
8. -1.3 camber (F), -1.0 camber (R)
9. 30mm Z32 brakes on front (have to have spacer)
10. Front and Rear rolled just in case
'11 M56S
'12 QX56 (wife's)
biggie is offline   Reply With Quote
Old 06-20-2005, 11:49 AM   #17
DriftSpecial180
DriftSpecial180's Avatar
DriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura aboutDriftSpecial180 has a spectacular aura about
2. Suspension Setup =SilkRoad RM/A8
3. Wheel/Rim Size front & back =15x6
4. Brand of Wheel/Rim =Infiniti G20
5. Offset front & back =45
6. Spacer Size = None Yet...
7. Tire Size front & back =205/60/15
9. Clear Zbrakes & what size brakes =Haha, No!!!
10. Fender Modifications: rolled/pulled =Haha, No!!! Again!!!
P.S. I know they're baby, but a lot of people can't decided if they want the "type x" look, this should help them. I'll be the guinea pig. These are just temporary till i can get some work equip 03's
DriftSpecial180 is offline   Reply With Quote
Old 06-30-2005, 11:55 PM   #18
samms95s14se
Just thought I would bring this back in case anyone missed it the first time around. I know we all don't check the forum every single day or at least I dont.
Later,
Old 07-01-2005, 12:20 AM   #19
jookybanana
jookybanana's Avatar
jookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfectionjookybanana is close to perfection
2. Suspension Setup = Zeal B6 (clears front coils by about 6mm)
3. Wheel/Rim Size front & back = 17x9 all around
4. Brand of Wheel/Rim = Titanium Bronze 5Zigen FN01R-C
5. Offset front & back = +20mm all around
6. Spacer Size = front 6mm (to clear coils), rear 10mm
7. Tire Size front & back = 215/40/17 falken fk451
8. Alignment Specs = front -2ish, rear -3ish
9. Clear Zbrakes & what size brakes = clears tt z brakes by like ~2"
10. Fender Modifications: rolled/pulled = rolled all around
jookybanana is offline   Reply With Quote
Old 07-01-2005, 06:52 AM   #20
i-love-my-s14
i-love-my-s14's Avatar
i-love-my-s14 is an unknown quantity at this point
1. S14
2. H&R Springs, Stock struts
3. Front 17 x 8.5 Rear 17 x 9.5
4. M2-Hanabi DT-05R
5. Front offset +25 Rear offset +30
6. No Spacers
7. Front tire 245/40/17 Rear tire 255/40/17, Yokohama AVS ES 100s & Falken ST115s
8. ?
9. Clears stock brakes
10. Front fenders are rolled
i-love-my-s14 is offline   Reply With Quote
Old 07-01-2005, 08:29 AM   #21
Johny5
Johny5's Avatar
1. S14
2. kts
3. F 18x9.5 R 18x9.5
4. Work Emotion CR Kai
5. F +12 F +12
6. 8mm spacer front (effectively making it +4 offset) 15mm spacer rear (effectively -3 offset)
7. F 235/40/18 ES100 R 235/40/18 FM901 rear
8. -3 camber front 8.2 caster 0 toe -3.5 camber rear companied with whatever toe-in that drop gives me
9. clears 2 sets of z brakes i'm sure
10. rolled fenders front rear pulled 1"
11. total ugly shit coming up!
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 07-01-2005, 10:28 AM   #22
ILiveToDrift
ILiveToDrift's Avatar
ILiveToDrift is an unknown quantity at this point
1. S13/S14/S15 = S14.5
2. Suspension Setup = KYB AGX w/ Sportlines
3. Wheel/Rim Size front & back = F:18x8, R:18x9
4. Brand of Wheel/Rim =Blitz Type=03
5. Offset front & back =F:32, R:30 (or somthing close to those)
6. Spacer Size =10mm in front to clear brakes
7. Tire Size front & back =F:245, R:255
9. Clear Zbrakes & what size brakes =with spacer 90 300zx NA
10. Fender Modifications: rolled/pulled =wider conversion wenders
ILiveToDrift is offline   Reply With Quote
Old 07-03-2005, 10:28 PM   #23
chmercer
chmercer's Avatar
1. s14 1995
2. KTS coils
3. front will be 18x10, rear 18x12
4. work equip m1
5. front -7, rear -20
6. none
7. front 245/35 rear 275/35
8. zero toe, front 7.5 caster -2.5 camber, rear -1.5 camber
9. clear z brakes by a mile
10. front will be cut and pulled oem, rear is version select overfenders
11.
i will edit with new pics when i get the front on there and lower, dont have tires yet
chmercer is offline   Reply With Quote
Old 07-04-2005, 02:19 AM   #24
CleanS14
it's NOT a show car!!
CleanS14's Avatar
CleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond reputeCleanS14 has a reputation beyond repute
VSKF's are gay...
Daily Pimpin'
1. S13/S14/S15 = s14
2. Suspension Setup = a lot of stuff
3. Wheel/Rim Size front & back = 18/19
4. Brand of Wheel/Rim = Chrome Work VS KF
5. Offset front & back = Perfect
7. Tire Size front & back = 225/40/18, 245/35/19
8. Alignment Specs = camber -2.7f, -2r, 7.5 caster, 0 toe
9. Clear Zbrakes & what size brakes = of course
10. Fender Modifications: rolled/pulled = slight roll no pull by mr. Dousan
Track Shoes
3. Wheel/Rim Size front & back = 18x9, 18x10
4. Brand of Wheel/Rim = Burning Black Work VS KF
7. Tire Size front & back = 225/40/18, 235/40/18
NAKAMA | ROOTS RUN DEEP
CleanS14 is offline   Reply With Quote
Old 07-05-2005, 02:36 PM   #25
KiDyNomiTe
KiDyNomiTe's Avatar
3. Wheel/Rim Size front & back = F: 15x6.5 R:15x7.5
4. Brand of Wheel/Rim = F: Longchamp XR4 R:SSR Reverse Mesh
5. Offset front & back = F: +11 R: +7
11. Picture..
PROCEED
Grip Gambler
Old 07-26-2005, 09:27 AM   #26
Ritz S14
Ritz S14's Avatar
1. S14
2. MR C/O Nismo TR Bushings
3. 18x9 18x10
4. Work Termist TM1
5. Offset front & back =?? leaves a nice dish though
6. Spacer Size = 0
7. Tire Size front & back = 225 40 18/245 40 18
8. Alignment Specs = None at the moment
9. Clear zbrakes front and rear
10. Front rolled, rear pulled
Old 07-26-2005, 11:02 AM   #27
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
1. S13 Hatch
2. Stock Supension
3. 17 x 9 front and rear
4. Falken Hanabi
5. +20mm front and rear
6. no spacer
7. f 225/40/17 r 235/45/17
8. Stock alignment
9. Tons of space so, I'm sure they will clear Z brakes. Just don't have them yet.
10. Will roll rear soon as possible. Rubs during hard cornering. Must roll before droping.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 08-04-2005, 09:31 PM   #28
s14dr1ft3r
s14dr1ft3r's Avatar
s14dr1ft3r is making a name for him/her selfs14dr1ft3r is making a name for him/her self
Just thought I would bring this back. Good piece of info for those looking for wheels. Anyone got a s14 with 18x8.5 F and 18x9.5 R with a Tein Flex/Super Drift C/O setup? Would like to see pics of that! Looking for the best offset/tire sizes. Thanks.
s14dr1ft3r is offline   Reply With Quote
Old 08-10-2005, 06:08 PM   #29
snatch13
snatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfectionsnatch13 is close to perfection
good work for bringing it back... lets see some more white zenki s14's!!! preferably gold wheels...
snatch13 is offline   Reply With Quote
Old 08-10-2005, 06:33 PM   #30
justinhustle
justinhustle's Avatar
justinhustle will become famous soon enoughjustinhustle will become famous soon enoughjustinhustle will become famous soon enoughjustinhustle will become famous soon enoughjustinhustle will become famous soon enough
1. S14
2. cusco comp zero 2, battle version arms
3. 18x9 F 18x10 R
4. Rays Gram Lite 57pro Face 2
5. Offset front & back = +22, +22
6. no spacers
7. 225/40/18 F 245/40/18 R Fuzion zri
8. -1 camber F, -3 camber rear
9. z32 brakes front, se rear
10. front rolled, rear rolled and pulled 5-7mm
justinhustle is offline   Reply With Quote
