Old 07-04-2005, 08:51 PM   #1
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
s13 Car bounces/shakes when drifting
Hey lately I’ve noticed that my car sometimes like starts bouncing like hell when I’m drifting, like I don’t use the e-brake, I power over, and it just starts shaking, until either I shift, or I let off the gas, wtf is making this problem, I’ve got a stock 240 (suspension wise) and got pretty new Falken Azenis on all 4. I thought at first it may be my shocks or some other suspension part, but I wanted some more opinions before I went off and spent lots of $ on every part, when I could just isolate the problem with a few.
Old 07-04-2005, 08:56 PM   #2
!Zar!
!Zar!'s Avatar
My guess is that your subframe bushing might be bad. Either that or it could be as simple as an alignment.
Old 07-05-2005, 12:06 AM   #3
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
lol get some good coilovers, my friend has kei office ones on his s13, just smootthhhhh, but while driving his car bounces a lot or too much cause it's set too stifffff
Indolent is offline   Reply With Quote
Old 07-05-2005, 12:44 AM   #4
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Bouncing sounds like a blown front damper.
Maeda is offline   Reply With Quote
Old 07-05-2005, 01:38 AM   #5
Irukandji
blown shocks + fast turns = wheel hop
the shaking and vibrating is ur wheel "hopping" thru the turn.. get new shocks or just go with coilovers.
Irukandji is offline   Reply With Quote
Old 07-05-2005, 06:01 AM   #6
punxva
punxva's Avatar
Trader Rating: (31)
ok, so basically i need some new shocks, well could u guys kinda help me on deciding which to get, cause i am kinda poor, and i dont know what to get. Cause i cant afford coilovers.
Old 07-05-2005, 08:38 AM   #7
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
Problem identified.
JaeTea is offline   Reply With Quote
Old 07-05-2005, 09:21 AM   #8
Dousan_PG
Dousan_PG's Avatar
power over isnt drifting
definately your shocks
very common, i drove a car like that. it sucked.
Aaron
Pink GodziRa
Old 07-05-2005, 12:06 PM   #9
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
if your poor then drifting probly isnt for you.... you should try modle cars or something..... g'day
SR240DET is offline   Reply With Quote
Old 07-05-2005, 02:01 PM   #10
kandyflip445
kandyflip445's Avatar
Just get some stock replacements for now and then save for some coilovers if you want to continue what you're doing. By the time those blow you should be able to afford some
My 240 vBgarage
Old 07-06-2005, 02:20 AM   #11
180InProgress
180InProgress's Avatar
180InProgress is an unknown quantity at this point
Stock suspension is not gonna cut drifting. First, the bushings are 9 times out of ten worn and spongy. Your spring rates and shock/struts probably feel softer than old man after a sponge bath. You're probably riding too high anyways. I went with a full Battle Version set up, Nismo power brace and Apex'I N1 EXV coilovers... I also installed rear suspension bushing collars to stiffen the rear bushings and damn was Impressed. My car bounces around on hard like nobody's business, but let me tell you, I haven't met a rice burner that can keep up with me around the corners.... straight away, they all got me burned.... but I got 'em at the corners, and that's where it counts. I would say if you can't afford to pay the cash for some good coilovers then get some good springs and shocks/struts for now. And the bushing collars are cheap as hell for the upgrade you'd get. Poly Uerethane bushings are also wicked for drifting, but unless you have a press or know a good cheap machine shop who's willing to cut a deal to press the bushings in for ya, you might as well drop $60 on some aluminum collars. SPL, has some good ones, or go cheap and get em from Ebay. All in all, I spent less than $2500 on my suspension and I have 32 way adjustable damping and can change every setting on my suspension the way I want it when I want it. Oh and if you want to ditch some of those old rubber bushings, pick up some rods/arms with pillow ball mounts instead.... stiff as hell ride, but all the control you need.
Stock is nothing.....
180InProgress is offline   Reply With Quote
Old 07-07-2005, 12:36 AM   #12
BrandC
BrandC is an unknown quantity at this point
You might want to use softer sidewall tires, usually a ROT is soft susp/soft tires, hard tires/hard susp. The azenis' might be a bit stiff and the stock susp. is doing all of the work. I noticed you said 4 new tires, and 4 new azenis' will definitely change the character of the car. And yes your shocks are probably tired/gone.
Also, $2500 susp. and a crappy driver...still makes a crappy driver. Upgrade to quality parts when you've truly outgrown a basic setup. Use advanced parts to help learning, not replace it.
BrandC is offline   Reply With Quote
Old 07-07-2005, 01:17 AM   #13
wutangben
wutangben is making a name for him/her selfwutangben is making a name for him/her self
Send a message via AIM to wutangben
drifting is definitely not a poor man's sport...
wutangben is offline   Reply With Quote
Old 07-07-2005, 05:13 AM   #14
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
LOL. this guy actually thought drifting on stock suspension was possible. Just because you see 240sx drifting. doesn't mean it's done on stock suspension. :retard:
driftingisgay.com
nrg is offline   Reply With Quote
Old 07-07-2005, 05:46 AM   #15
sLip techniques
sLip techniques's Avatar
sLip techniques is an unknown quantity at this point
yeah ok nobody can drift on stock suspension
people on Zilvia need a big ol
sLip techniques is offline   Reply With Quote
Old 07-07-2005, 08:34 PM   #16
punxva
punxva's Avatar
Trader Rating: (31)
ok NRG, im a nice guy, so im not gonna start a flame war with you, but what u are saying totally contradicts everything the whole drift community recommends about drifting. And that would be... Learn on what you've got, then once your comfortable, then you should begin to upgrade. Just as BrandC Said,
So if ur gonna call some1 a retard, then u might wanna look in the mirror cause all i wanted was some honost help, not some trying to give me shit cause he thinks hes all big and bad.
Old 07-07-2005, 08:59 PM   #17
TheTimanator
TheTimanator's Avatar
NRG is just screwing with you cuz your a just another newb thats asking questions about drifitng :sigh:
Nothing against you though...
