Old 07-06-2005, 04:22 AM   #1
nevaland9
nevaland9's Avatar
nevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfection
Send a message via AIM to nevaland9
KA J30 LSD Ratio v.s S13 Ratio
i have a 91' 240sx fastback. it has a infiniti J30 lsd and it dosnt feel that fast, i dont know if its the car or the ratio is to tall for my basicly stock engine.
Can someone get the the ratios for the J30 LSD and the ratio for the stock open diff? or give me a explination. im pretty sure the j30s ratiso are taller but i would like to know exact number and if i should switch over the stock ring and pinion (if possible)
thank you,
Jason
nevaland9 is offline   Reply With Quote
Old 07-06-2005, 06:26 AM   #2
orion::S14
orion::S14's Avatar
TONE DOWN THE BIG LETTERS AND BOLD TEXT...damn.
And [search + J30 + gear ratio] would give you a quick answer.
...or see here: www.KA24DEvelopment.com/vlsd.html
- Brian
Old 07-07-2005, 12:24 AM   #3
BrandC
BrandC is an unknown quantity at this point
The website says the stock open diff is only 4% taller, so it shouldn't matter. It's like changing tire sizes.
BrandC is offline   Reply With Quote
Old 07-07-2005, 12:33 AM   #4
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
why is ur font so damn big..
anyways J30 final drive is 3.9 on the ring gear its stamped 47:12.. 47/12 = 3.916666666666
crack open ur open diff and look at what is stamped on the big ring gear, and then do the math urself... not that hard...
Sfourteen
dct223 is offline   Reply With Quote
Old 07-07-2005, 12:34 AM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
plain and simple the info is right here on Zilvia if you used the search button. Oh and that website has it backwards taller gears mean lower numbers which translate to higher top speed hence taller and slower off the line acceleration. shorter gears are higher numbers which translate to lower top speed but quicker off the line acceleration response.
New Video
Buy my mounts!
Old 07-07-2005, 12:35 AM   #6
Ritz S14
Ritz S14's Avatar
Did you loose your opitcals or something?
Davis, look who's talkin. Go crack open your vlsd!!
Ritz S14 is offline   Reply With Quote
Old 07-07-2005, 07:03 AM   #7
orion::S14
orion::S14's Avatar
Originally Posted by drift freaq
...Oh and that website has it backwards taller gears mean lower numbers ... shorter gears are higher numbers ...
Where? The only spot I mention taller gears is:
Originally Posted by www.KA24DEvelopment.com
J30 diffs have a 3.916 ratio, which is 4% taller than the stock open differential...
Is that what you were reffering too, or am I missing something? Let me know, I don't want bad info on my site...
- Brian
