Old 07-12-2005, 04:53 PM   #1
Weirsy
Weirsy is a well-known jackass
Send a message via MSN to Weirsy
s14 Cleaning my HKS Air filter
So this is the first time i decided to clean this thing as it was lookin kinda dirty.
So i went and bought K + N air filter leaning kit. My thoughts were that it should basically do the same as any other cleaner. Correct?...well i used the cleaning solvent and all the grease, or w.e it is, black shit ran off and the filter was lookin almost brand new.... Then part II... Oiling it. Was i even supposed to do this? cuz i oiled it and it turned the inside of the green filter purple. Now i dont see why this matters, but i saw no trace of purple when i cleaned it before so im just wondering.
Do i continue along with the K+N cleaning instructions and do the 2nd coat of oil and then dry and install.
or
Do i clean the filter back to how it was after step one and either install or do somehting different from here?
Thanks guys
Mike
Weirsy is offline   Reply With Quote
Old 07-12-2005, 05:05 PM   #2
uno
uno is an unknown quantity at this point
Send a message via ICQ to uno
or
Thanks guys
i don't think the hks filter is an oiled filter. so no you shouldn't oil it
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels.
uno is offline   Reply With Quote
Old 07-12-2005, 05:16 PM   #3
Ritz S14
Ritz S14's Avatar
Hks filters are not reusable.
Ritz S14 is offline   Reply With Quote
Old 07-12-2005, 05:34 PM   #4
TheSquidd
TheSquidd's Avatar
Shoulda bought a K&N Filter to go with the cleaner
If this is the HKS foam filter, I'd trash it, soon you'll be having foam pieces sucked into your engine, which I hear is not a good ingredient for combustion. Swap it out with a K&N universal clamp on and you should be fine, and probably be flowing better.
Plus, your filter wasn't made to be oiled, and I imagine doesn't absorb the oil quite as well as a real filter should, running on an oiled HKS filter will probably end up with you sucking up oil residue into your MAF and messing that up.
TheSquidd is offline   Reply With Quote
Old 07-12-2005, 05:34 PM   #5
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
That element is not re useable!!!!
Buy a new one...
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 07-12-2005, 05:38 PM   #6
Weirsy
Post
Ok thanks guys.... I was told it was re-usable but i guess not so im going to hafta buy a new filter, ill probly go k+n since i have the cleaning supplies haha but we'll see...
Thanks again
Mike
Old 07-12-2005, 05:47 PM   #7
kuramaya
I never heard of the HKS breaking upa nd foam going into the compressor or N/A intake manifold....and I know guys running them on 400 HP motors...as long as it is clean you are fine...The APEXi is the preffered intake won best for cleanliness and HP increase on a few tests I have seen that were not run by the company..K&N is good, but they always collapse after a fw cleaning and use....look at someones older K&N, bet it is not the orginal shape
Old 07-13-2005, 12:41 AM   #8
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
I had the HKS smf and I didn't oil that thing. But it did kill my maf since it doesn't filter that much and decided to change it. I put on an K&N kit, adapter with velocity stack and the filter and it pulls harder at higher rpms. It is carb legal compared to the universal K&N filter. Go to their website to look at it.
I'm driving fast
-drew
drew935 is offline   Reply With Quote
