Old 07-12-2005, 01:31 AM   #1
dirtysouthjuggalo
dirtysouthjuggalo's Avatar
dirtysouthjuggalo is a well-known jackass
Send a message via AIM to dirtysouthjuggalo
weird noises
my rear end is making a few noises all of a sudden . it squeeks really loud when im going slow 0-25mph and there is a slight gringing noise most of the time kinda like brakes . pulled the wheel the brakes are fine everyhthing is on good and there is no scoring on either side of the rotors. anyone have a clue? im thinking mabey ball bearings or diff any thoughts?
dirtysouthjuggalo is offline   Reply With Quote
Old 07-12-2005, 03:25 AM   #2
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
When you pulled the wheels to inspect the brake pads, how much pad material was left on the pad?? You check both INNER & outer pads?? If both the inner & outer rear pads have plenty of pad material on them, then it's possible it could be brake dust on the shims or sticking caliper pins. If there is little pad material left on the pads, then chances are the brake wear indicator is barely touching the rotors...Give it some more time....the squealing will get louder as the brake pad material wears out. You might want to slap on a new set of rear brake pads if you already haven't done so.
If you've already swapped out your rear brake pads, then you might want to try using a different brand when you go to replace them.
Anyhow, hope this helps...
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 07-12-2005, 11:00 PM   #3
dirtysouthjuggalo
i checked and they are fine the were changed like a month ago i think im gonna repalce my bearings and if thats not if then at least ill have new bearings
Old 07-13-2005, 12:54 AM   #4
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
check your subframe bushings and yeahh check your diff too
TAMTANIUM is offline   Reply With Quote
Old 07-14-2005, 12:48 AM   #5
dirtysouthjuggalo
hmm think that could be it? i have some sub frame bushings i havnt put in yet and im about to get a new lsd guess ill check then
