Old 07-20-2005, 09:03 PM   #1
The Hamsterball
The Hamsterball's Avatar
The Hamsterball is making a name for him/her selfThe Hamsterball is making a name for him/her self
Driveshaft-Differential problem
Hi..
I have done the S14 VLSD swap into my S13 a while ago, it fixed a lot of the noise problems I was having with my clunky open diff which had play in the output shafts (no good).
Now, I don't get any of the insanely loud clunks that I used to get with the Open diff, but I still have some noise. It's the same noise as before, but not as loud.
*ClunK*
If I shift and engage too fast, *clunk*
If i let out the clutch too fast in 1st when trying to engage (without using any gas), it clunks.
If I drive PERFECTLY and engage in every gear slowly and with an exact match, no noise*
I have been in a friend's S13, who drives no where as carefully as me, and there is absoulutely no noise.
I know that my non-abs S13 driveshaft is .75'' longer than an S14 ABS driveshaft (i believe).
I would like to know if that has something to do with the problem? Should I get an S13/S14 ABS driveshaft welded somewhere?
Or if the .75'' lenght difference doesn't matter, where else should I check, what else should i grease up, what should i do to fix this noise?
White '90 S13 Fastback (SOLD in '07)
The Hamsterball is offline   Reply With Quote
Old 07-20-2005, 09:06 PM   #2
kandyflip445
kandyflip445's Avatar
Subframe bushings??
My 240 vBgarage
Old 07-20-2005, 09:21 PM   #3
aznpoopy
aznpoopy's Avatar
Originally Posted by kandyflip445
Subframe bushings??
+1
just get some subframe bushing collars
Old 07-21-2005, 02:59 AM   #4
Drunk Bastard
Drunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really nice
Send a message via AIM to Drunk Bastard
ok, here's what you do:
1=buy aluminum driveshaft
2=install welded diff
Drunk Bastard is offline   Reply With Quote
Old 07-21-2005, 03:25 AM   #5
The Hamsterball
Subframe bushings??
eehh... okay i'll take the advice for the driveshaft.
It's time for some new u-joints.
(i verified the problem by lifting the rear and rotating the wheels.
the u-joint clunked alot more than the output shafts on the VLSD)
And I heard subframe polyurethane spacers make differential noise worse.
Maybe they said wrong.
Also, I notice that my stupid assed output shafts have play now...
they had zero play before i installed the differential.
This is retarded.. ahaha.
Thanks for not helping out and leaving all my questions unanswered though.
It's like those dumb posts on overheating threads.
"uh... maybe it's your thermostat. Just buy a nismo t stat"
"uh... it's your radiator for sure. Try a flush"
(responses with NO backing or reasoning except diagnostic guesses.)
I can't really relate to the way you guys post up there.
But I'll go ahead and try the subframe collars, since I was going to purchase and install those in the future anyways.
Old 07-21-2005, 04:02 AM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Originally Posted by The Hamsterball
Subframe bushings??
IIRC, they increase cabin noise, but keep the rear subframe from flexing and gettin liquid. And don't hate on Zilvian and their suggestions. Its like going to a doctor. He'd SUGGEST it might be this, but wouldn't give an exact 'thats the problem' cuz if he was wrong, it'd b malpractice. Think of it the same way here. ALthough we can't hear the problem, and physically inspect it, we cover all possible problems before pinpointing the true nature of the noise.
Glad we could have been of help.
And sorry if that sounded like a flame.
'I am not the Human Torch.'
SochBAT is offline   Reply With Quote
Old 07-21-2005, 07:40 AM   #7
240m3srt
240m3srt is an unknown quantity at this point
I have the exact same clunk and im doing subframe bushings along with diff bushings this weekend. Ill let you know if that fixes it.
240m3srt is offline   Reply With Quote
Old 07-21-2005, 10:26 AM   #8
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
i had a nasty clunk just like this, after replacing the tranny mount and the diff bushinngs, the subframe spacers finally fixed it, just took up the slack in the old shitty stock bushings, took 15 min to install, best mod ever =]
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 07-21-2005, 11:18 AM   #9
kandyflip445
Ok, Hamster turd. I suggested subframe bushings because of the clunk. As did a couple other people. If you don't like the answers then don't ask for help. It's not like we can 100% correctly diagnose your problem over then internet. If you want that done take it to a mechanic. Even then they sometimes don't tell you what you want.
My 240 vBgarage
Old 07-22-2005, 12:41 AM   #10
The Hamsterball
Meh.. you guys are right.
I should be happy at least for suggestions that relate to possible areas of problem for the exact problem, but shouldn't expect an exact answer.
(i was kind of tired and disgruntled from work at the time of the post).
Well, I can't really get any differential bushings. I'm using custom washers, with longer differential mounting bolts. The washers are pretty damn thick, my dad made them at work (he's handy, but not automotively-tuned lol)..
The ony other area I can see that might mean that the differential is not on correctly is how all 4 of my rear cover mounting bolts (or maybe the rear cover threads) are kind of fucked.
(meaning, all of them got tight, and then got loose.
I believe I overtightened them with higher than required torque specs when I put the differential in)
They're still tight and holding it well, and not much I can do about that problem unless I take the diff out, or if it is the bolts that are fucked up and not the rear cover thread.
I pushed my leg up against the diff as well, no movement.
Lastly, I did what somebody suggested in a thread I came across when searching.
(Lifting the rear end up, and rotating the wheels.
Found that my output shafts don't have any play, and there is a *clicking noise* that could be a *CLUNK* when the car is really driving with more pressure than my bare hands.. ---Coming from the U-JOINT--
I believe the problem lies in my driveshaft assembly (Most probably the U-Joint)
Thanks for all the help and suggestion, it helped me narrow it down to the problem.
Also, this post is just to add on to the thread in case some other Zilvian has the same problem.
Thanks again.
Old 07-22-2005, 12:51 AM   #11
The Hamsterball
Oh yeah....
Can anybody verify if it is a BAD THING to use an S13 non-abs driveshaft for the S14 VLSD from an ABS equipped car.
The driveshaft of the S14 that the VLSD initally was on had a driveshaft that is .75'' shorter (as said on ka24development.com)
I had no problems getting the shaft to fit on the diff, but am wondering if it is a bad idea or if it puts too much stress since it's longer and has to kind of squeeze itself in to line up to the input shaft of the VLSD.
(I remember reading something about this, and think I read something that made my mouth open.. Something about adding extra pressure/stress to the inners of the VLSD)
I wouldn't have worried about this if I didn't have a new rumble noise coming from the rear occasionally on DECELERATION.
It comes very rarely.
That scares me lol.
But other than that, thanks for the suggestions.More importantly, Does anybody know about 240SX Rear U-joints, the ones that connect to the diffential shaft flange? Do you have to grease them or anything? Or do they not have grease?? I am kind of confused in this matter, and am wondering if there is a way to servicve them or just buy a new rear driveshaft section to fix the problem.
Old 07-22-2005, 02:19 AM   #12
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
from what i've READ, if you have enough "slack" in your driveshaft, you should be fine. as far as the other stuff, i'm not positive enough to say
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 07-22-2005, 02:37 AM   #13
kandyflip445
In the FSM it says if it's broke you have to replace the whole shaft. With exception of the center bearing, which can be replaced.
My 240 vBgarage
Old 07-22-2005, 08:05 AM   #14
statik
statik's Avatar
Oh yeah....
this is a bad thing, I made the same mistake, threw on an s13 vlsd w/abs on my base kouki w/o abs and thoughy since it fit it would be ok, it destroyed the carrier bearing, which I then replaced with a 1 piece aluminum DS...gl =]
Old 07-27-2005, 12:57 AM   #15
The Hamsterball
awww shit..... that's what i thought.
thanks alot...
oh well.
Old 07-28-2005, 10:18 PM   #16
golfer17
golfer17's Avatar
golfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nice
Send a message via AIM to golfer17
where did you get your aluminum ds made(im assuming a local ds shop) and how much did it cost you. i need to get one made for my auto-manual (ka24de-s14sr also)swap but i wont be getting a ds with my front clip, so where can i find all the measurements for the right ds i need? i also need the carrier bearing bracket too, can i get this made too or just get it from a junkyard?
golfer17 is offline   Reply With Quote
Old 07-28-2005, 10:25 PM   #17
projectRDM
projectRDM's Avatar
Tension in the driveshaft rarely makes noises, and if anything it will slightly increase wear on the carrier bearing and the transmission output shaft seal, but that's it. Most cars have enough play between diff/gearbox/motor mounts to accomodate the added length. The sound you're describing, if it was driveshaft induced, would mean that there is too much play in the shaft, the opposite of your situation.
Ujoints are not replaceable on a Schassis shaft, so either buy a new one or start salvage hunting.
FORMERLY R240NA
Old 07-28-2005, 10:38 PM   #18
TheTimanator
TheTimanator's Avatar
really? I've had a J30 VLSD in my car for over 20k miles and no problems I am aware of.
Old 07-29-2005, 02:00 PM   #19
statik
statik's Avatar
perhaps mine was just on its way out, im always looking for reasons to upgrade =]...i got my DS from the driveshaft shop , they happen to be located about a mile from where i work
