Old 07-30-2005, 08:46 PM   #1
xagna
xagna has a little shameless behavior in the past
Any one know this impact gun?
I'm thinking about purchasing this electric impact gun. Have you heard of this company znex? If you are using this one, I would like to know if this one would be enough to pull wheel lugs or suspension strut lugs.
Znex (ZNXCI2182) 1/2" Dr. Cordless 18V Impact Wrench Kit - 240 Ft.Lbs. - FREE SHIPPING!
http://www.tooltopia.com/index.asp?P...OD&ProdID=9746
The Znex CI-2182 is an affordable 1/2" drive cordless impact with the turning power to previously only found in premium brand wrenches.
Includes 18V Znex Impact Wrench, 2 batteries, 1-hour quick charger, impact resistant carrying case.
Specifications:
Square drive: 1/2"
Rotation: Forward and reverse
Net Weight: 6.2 lbs.
Battery Charge Time: 1 hr
Voltage: 18 Volt
Impact Per Minute: 2,800
Maximum Torque: 240 Ft.-Lbs.
Free Speed: 2,300 RPM
xagna is offline   Reply With Quote
Old 07-31-2005, 10:29 AM   #2
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
sounds like it should do the job, I would worry about how long it holds a charge while you're working with it.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 07-31-2005, 12:18 PM   #3
xka24detx
xka24detx is an unknown quantity at this point
it looks decent, try looking at harbor freight tools http://www.harborfreight.com/ they got alot of tools and parts that are cheap and the quality is decent.
xka24detx is offline   Reply With Quote
Old 08-02-2005, 10:52 PM   #4
xagna
Thanks for the replies guys,
Will this one do a coilover swap job if necessary?
Old 08-02-2005, 11:04 PM   #5
xka24detx
it should be able to, my friend and i did a spring install just using a socket wrench, and a cheapo breakerbar that flexed like hell.
