Old 07-30-2005, 09:22 PM   #1
Spike913
Spike913 is an unknown quantity at this point
BLITZ SBC ID set at 10PSI/ boosting only 7s
Yea i just installed the blitz Sbc id boost controller and i set it at 10 psi, but its only boosting at 7 psi from the boost gauge.
stock air box
hks FMIC
downpipe
test pipe
hks hi power exhaust
walbro 255 fuel pump
Can it be just tunning?
Spike913 is offline   Reply With Quote
Old 07-30-2005, 09:32 PM   #2
PROJECTRB240SX
PROJECTRB240SX is an unknown quantity at this point
did you splice your vacuum hose between the hotpipe and the wastegate?
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY!
PROJECTRB240SX is offline   Reply With Quote
Old 07-30-2005, 09:59 PM   #3
Spike913
my friend did the install and i assisted him...
i dont kno too many parts on cars but
all i remember is that we connected a vacume hose from the IC pipe b4 the throttle body (cold air from IC) to the solenoid and out from the solenoid to the actuator/ waste gate.
and to get boost readings we ran another hose line from the fuel management or something, which is located right on top of tha throttle body.
is the hot pipe the pipe after the turbo to the IC?
Old 07-30-2005, 10:05 PM   #4
Spike913
o yea i have an apexi BOV if that has to deal with anything
Old 07-30-2005, 10:16 PM   #5
PROJECTRB240SX
hot pipe is the line from turbo outlet to IC. You are reading manifold pressure with your gauge and referencing a different pressure for the turbo. If you want a correct boost reading hook up your gauge to the same place as your boost controller.
Ok your turbo is making 10 psi.... but only 7 psi is hitting the manifold. The manifold pressure is always lower than the turbo pressure. Try setting your boost controller to stock or just simply turn it off now take a reading.... the stock turbo goes to 7 psi which is normally around 5psi manifold pressure.
Old 07-31-2005, 09:06 AM   #6
Spike913
i lowered down the boost too 7 psi and im still running 7 psi
Instructions http://www.team3s.com/Blitz%20SBC%20i-D%20manual.pdf
Old 07-31-2005, 09:11 AM   #7
PROJECTRB240SX
I think it has something to do with your plumbing.... either you have your vacuum hoses backwards on the bleed valve, you don't have it spliced into actuator line, your referencing the wrong vacuum port, your wiring is wrong on the unit itself, or you have a defective unit.
Old 07-31-2005, 09:13 AM   #8
Spike913
o yeah i think we set it up like the external wastegate, but arent we suppose to set it up like the actuator since the SR comes stock wit the actuators?
my previous set up was that there was a line from the cold pipe connected to the actuator, shouldnt it be the line from the turbine to the actuator?
Old 07-31-2005, 09:48 AM   #9
PROJECTRB240SX
Its normally from the hotpipe or compressor outlet to the actuator. Then you splice in there and use that as the reference also if you want to set turbo pressure.... if you want to set manifold pressure take a vacuum port off the manifold.
