Old 07-30-2005, 07:40 PM   #1
BlazedGlory
BlazedGlory will become famous soon enoughBlazedGlory will become famous soon enoughBlazedGlory will become famous soon enough
Rod/Main Bearings?
I have an S13 SR20DET, and plan on doing a slight build before I slap a bigger turbo on, cams, valve springs/retainers, possibly pistons/rods (not sure yet), main/head studs, etc.
I've read it is a good idea to do bearings as well. In searching I read there are different sizes and whatnot? Should they be measured to check engine wear or something before you buy new ones? I found these on ebay - they are available in standard, .25, .50, and .75mm oversized - would I just get standard? I'm just trying to get all the parts together that I can before I even begin to start actually upgrading the engine...
http://cgi.ebay.com/JDM-NISSAN-SR20D...QQcmdZViewItem
thanks!
BlazedGlory is offline   Reply With Quote
Old 07-30-2005, 09:05 PM   #2
240witsr
240witsr is an unknown quantity at this point
read the FSM... it will answer all your questions on bearing selection as well as what and how to measure what needs to be measured.
240witsr is offline   Reply With Quote
Old 07-30-2005, 09:08 PM   #3
idiot goes sideways
idiot goes sideways's Avatar
idiot goes sideways is an unknown quantity at this point
that depens on your crankshaft, you should dismount it and check for scratches
than you should check the size and after that you can tell if you need oversize bearings you cant buy it before you cheked it (probally you can but i would be airheaded)
idiot goes sideways is offline   Reply With Quote
Old 07-30-2005, 10:02 PM   #4
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
thanks!
wow... just... wow... not sure if you should touch the internals..... sounds like you gotta some some more research....
are you sure you know what your getting into?
SR240DET is offline   Reply With Quote
Old 07-31-2005, 10:21 AM   #5
BlazedGlory
with the bearings I have no idea what I'm getting into to be totally honest. The rest shouldn't be too difficult, but I have 4 mechanics who can help me along...
Old 07-31-2005, 01:47 PM   #6
BlazedGlory
will it really even be necessary to get new bearings?
Old 07-31-2005, 08:30 PM   #7
240witsr
how many mechanics does it take to rebuild or chose bearings?? :hammer:
READ THE DAMN FSM!! It will tell you all that you need. Must i say it again?? Measure the crank journals O.D., measure the I.D. of the main galley with the caps torques down properly and using a bore scope, subtract the two numbers and see if its within spec.
Old 08-01-2005, 06:33 AM   #8
BlazedGlory
