Old 08-02-2005, 07:46 AM   #1
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
Fan wiring question
I am in the middle of replacing my Flexalite dual 10" setup with Altima fans. They're already trimmed and mounted but I'm having trouble with the wiring.
I've got relays and a controller (Pivot) wired in so that's no problem but I've had no success in figuring out which wires are which on the fans themselves.
I know the Altima fans are two-speed units; I'd like them to run on high when they run. I've read several conflicting reports on which wires are which.
Can someone tell me for certain which wires are power and which wires are ground, to run the fans on high speed?
TIA
Rittmeister is offline   Reply With Quote
Old 08-02-2005, 07:51 AM   #2
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
You should have searched. Its been covered for shizzle.
http://www.240sx.org/links/installs/efans/index.html
http://www.240sx.org/links/installs/...ctric_fans.htm
http://www.240sx.org/links/installs/...an_install.htm
Those should help you. And thanks for searching.
SochBAT is offline   Reply With Quote
Old 08-02-2005, 08:51 AM   #3
Rittmeister
OK.
1. I searched. Didn't find my answer. I've seen all of those writeups and they don't help me a bit. For the record, I've been running the 10" fan setup with relays and Pivot controller for months now with no trouble. I wasn't asking how to wire fans up.
2. You didn't read my question carefully, and I admit on re-reading it that I worded it poorly.
So, I'll re-ask it:
Which wires ON THE ALTIMA FANS are power and ground for the high speed fan setting? There are four wires sticking out of each motor, black/blue/green/yellow, and I simply need to know which are which.
Thanks again.
Old 08-02-2005, 09:06 AM   #4
pr240sx
pr240sx is an unknown quantity at this point
Note that you need to energize both pairs to use high speed setting.
Also note that each pair is separated. Apply same polarity to each one. Black/blue are ground and green/yellow are positive.
To use the low speed, only apply current to one set (black- green+ or blue- yellow+) it does NOT matter.
Alti fans blow quite hard at high speed, they also could drain your battery quite fast. For normal driving, the low speed is enough.
pr240sx is offline   Reply With Quote
Old 08-02-2005, 09:25 AM   #5
Rittmeister
Are you absolutely sure on the colors? I powered blue and grounded black (on another thread's advice) and the fan came on (this was just a test), but you're saying they're both ground wires.
I'm really confused here.
Old 08-02-2005, 10:21 AM   #6
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Blue/Green to "+", Black/Yellow to "-" = fan on high.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 08-02-2005, 12:00 PM   #7
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
that didnt answer any part of his question....
SR240DET is offline   Reply With Quote
Old 08-02-2005, 12:08 PM   #8
Rittmeister
I'm glad I'm not the only one who noticed...
I just wired them according to Replicant_S14's suggestion and they run fine. I'm eventually going to install a switch in the ground side to have a hi/lo option but for now I'm good to go.
Thanks to all who answered my questions!
Old 08-03-2005, 09:05 AM   #9
pr240sx
I listed the colors just to reference.
You can use whatever polarity on whatever wires. They will always turn on on the right direction.
Anyway, glad you got it to work.
