Old 08-01-2005, 07:47 PM   #1
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
Wheel bearing bad???? help!
ok... noise is coming from the right front wheel. Sounds goes round and round and round and round and.... well, you get the idea. I found 1 thread about this when I searched, but, the problem was never solved. Do you guys think it's a wheel bearing? If so, how hard are they to replace. Also, I just got some wheels, 17x9... I don't know if this matters.
240silvia is offline   Reply With Quote
Old 08-01-2005, 08:08 PM   #2
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
I am in the process of replacing a right front wheel bearing....so IMO your problem sounds precisely the same. If the sound is proportional to your speed and it does change pitch around turns, you can almost bet it's the WB.
bshotts is offline   Reply With Quote
Old 08-01-2005, 08:12 PM   #3
240silvia
240silvia's Avatar
you are in the process of replacing it???? That sounds like it's hard.... lol.
Old 08-01-2005, 08:17 PM   #4
PROJECTRB240SX
PROJECTRB240SX is an unknown quantity at this point
I thought 240sxes have sealed hubs?
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY!
PROJECTRB240SX is offline   Reply With Quote
Old 08-01-2005, 08:51 PM   #5
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
For S13's you can buy the bearings separate from the hub, you need to press out the old and press in the new.
I just did mine on my s14, but I had to get the whole hub, I can't get the bearings alone.
Getting the bearings pressed out/in will take longer than mine did.
Just remove wheel, remove caliper, remove rotor, remove hub nut, hub slides right off
Get bearings pressed
Slide in hub, tighten hub nut (150-200 ft/lbs tq.), install rotor, install caliper, install wheel.
18+ to come//21+ to swallow
anthony240 is offline   Reply With Quote
Old 08-01-2005, 10:30 PM   #6
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
S14 has sealed hubs, S13 are replaceable.
WilloW is offline   Reply With Quote
Old 08-02-2005, 12:33 AM   #7
Var
Var's Avatar
Send a message via AIM to Var
Wheel bearings usually make a whining or a deep whirring sound. Not round and round like maybe...used up brake pads. It doesnt seem like you're describing wheel bearing noise. Can you describe the noise any better? Is it more apparent on the freeway? Does it get louder if you turn the wheel at speed...say like sweeping turns on the freeway...?
Hi
Old 08-02-2005, 03:47 AM   #8
*Kouki_Monster*
*Kouki_Monster*'s Avatar
*Kouki_Monster* is an unknown quantity at this point
Don't be intimidated by changing it.
But make sure you know its the problem
first.Yeah can you give us a few more
detailed sounds.
Image exceeds forum 150kb. limits.
*Kouki_Monster* is offline   Reply With Quote
Old 08-02-2005, 09:27 AM   #9
anthony240
anthony240's Avatar
mine actually made a clicking sound when they went bad.
Old 08-02-2005, 10:36 AM   #10
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
I have a few sets of hub/spidle assemblys complete fornt and rear, pm me if interested.
CHARLIE2020 is offline   Reply With Quote
Old 08-02-2005, 03:23 PM   #11
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Load and unload the wheel bearing and see if the noise almost goes away when it is unloaded. You can do it by steering left the right fairly hard...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 08-02-2005, 03:41 PM   #12
240silvia
240silvia's Avatar
it gets louder when I reach about 30mph. Just going down the road.... it almost sounds like a truck with MT's on it.... not that loud of course... but same tone. any help?
Old 08-02-2005, 06:59 PM   #13
Var
Var's Avatar
ya.. it drones like some big tires. It's the bearing.
Hi
Old 08-02-2005, 07:47 PM   #14
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Wider/lower offset wheels can cause wheel bearings to fail faster than stockers since they increase the stress on them. But yeah, bad wheel bearings almost sound like your tires are really out of balance or something. Happens at certain speeds as well, not throughout everything. The hub assembly for my VW was 180 bucks, EACH. GR!
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 08-02-2005, 11:06 PM   #15
*Kouki_Monster*
Yeah most likely its your wheel bearing now.
Its worth a change anyways since you got
a old model car.
Old 08-03-2005, 12:34 AM   #16
SaGang227
SaGang227 is an unknown quantity at this point
Here is something you can do to test it.
Lift up the front of the car and shake the wheel holding the top and bottom of it.
By this, I mean push the top and bottom of the wheel alternatively as you are facing it.
If the wheel bearing is bad, you can feel it moving when you shake it.
Hope this helps you.
SaGang227 is offline   Reply With Quote
Old 10-11-2005, 06:46 PM   #17
zenki s14
zenki s14 is an unknown quantity at this point
sorry for bringin up an old thread, just wanted to confirm for s14 5 lugs. We can't replace the wheel bearings? We have to buy new hubs?
zenki s14 is offline   Reply With Quote
Old 10-11-2005, 06:55 PM   #18
sw20>>s14
sw20>>s14's Avatar
you can buy/switch new bearings, you just have to get your old bearing unpressed from your current hub and press the new one into the same hub...so two bearings, one hub...in with the new, out with the old...only tricky thing (unless you have access to a press) is the unpressing/pressing process...
sw20>>s14 is offline   Reply With Quote
Old 10-11-2005, 07:06 PM   #19
zenki s14
the local auto stores, and dealer won't sell the bearings seprate, I'm planning to go to a machine shop to get them pressed out.
Old 10-12-2005, 02:22 AM   #20
sw20>>s14
sw20>>s14's Avatar
okay...then supposedly if the bearings arent available, what are you gonna do after you go to a machine shop and press em out?...
thats because: http://performancenissanparts.com/ca...oducts_id=1097
how hard was that? mmmMMMmmmMMM bout 12 secs...i suggest you order from here...eddie will definitely take care of you...
Old 10-12-2005, 02:40 PM   #21
zenki s14
Thanks a lot. Living on a rock, Im limited to options. Got to love the online stores.
