Old 08-03-2005, 12:25 PM   #1
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
Kazama tie rod ends bowshet
This isnt cool right?
looks like alot of stress on the heim and I even rearanged the spacers so that the bigger one is on top what can I do? tighten everything up and leave it like this? These were supposed to fix the bumpsteer
TokyoNights is offline   Reply With Quote
Old 08-03-2005, 12:58 PM   #2
KOUKI KA-T
KOUKI KA-T's Avatar
KOUKI KA-T is on a distinguished road
red x's
Copy and paste no workie
My car has been sold
KOUKI KA-T is offline   Reply With Quote
Old 08-03-2005, 01:05 PM   #3
TokyoNights
crap how about this
Old 08-03-2005, 01:07 PM   #4
NismoSilvia270R
NismoSilvia270R's Avatar
NismoSilvia270R is an unknown quantity at this point
Send a message via AIM to NismoSilvia270R
does it fix itself when you drop the car?
NismoSilvia270R is offline   Reply With Quote
Old 08-03-2005, 01:08 PM   #5
Saisoku
Saisoku is on a distinguished road
That does look pretty extreme.
What chassis inner rods do you have? And what chassis ends do you have?
Saisoku is offline   Reply With Quote
Old 08-03-2005, 01:31 PM   #6
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Did you get an alignment and are they perfect? Looks like its way too short.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 08-03-2005, 01:38 PM   #7
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
yeah, it just looks like you need to make the end come out more, and you might want to put the spacers back to the way you had them (bigger one on the bottom) and just raise your car a bit more to reduce bumpsteer. i had my spacers like that and it bent because of the added stress.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 08-03-2005, 02:04 PM   #8
KOUKI KA-T
KOUKI KA-T's Avatar
Looks like you're using z32 inner tie rods tein/s14 size ends....
What inner tie rods are you using?
Old 08-03-2005, 02:10 PM   #9
TokyoNights
not really the car is so stiff it doesnt really settle when you drop it.
car is a s13 with s14 tein inners using the spacer. s14 kazama outers
I had an alignment not too long ago before I put these on, I just measured the moog ones I had and did these the same length. Also if I try to make them longer it binds up cause see the angle of the mounting point on the spindle?
I cant make them come out more on the second pic look at the angle of the spindle. And I cant raise it its against my religion
Old 08-03-2005, 02:15 PM   #10
Saisoku
Correct me if Im wrong, but if you use S14 inner rods arent you supposed to use S13 ends? Forgive me but I dont feel like searching.
Old 08-03-2005, 02:21 PM   #11
TokyoNights
Nope,the threads are different and the s14 inners have a bigger diameter.
Old 08-03-2005, 02:41 PM   #12
Dousan_PG
Dousan_PG's Avatar
s14 or s13 FLCAs?is your steering wheel turned??
did you get an alignment?
something aint right son!
Aaron
Pink GodziRa
Old 08-03-2005, 02:55 PM   #13
TokyoNights
s13 flaca. Wheels dead straight. I will do another alignment myself once the fastrax kit comes in.
WTF!?mabie Im just too low but thats not gonna change.
Old 08-03-2005, 02:55 PM   #14
A Spec Products
A Spec Products's Avatar
tein S13 and S14 inners are the same thing.
part numbers the same, same diameter.
A SPEC PRODUCTS CORP
Old 08-03-2005, 03:17 PM   #15
Flybert
It just looks like you need to lengthen the tie rod and go get an alignment. What does your toe look like with it like that? I bet it's mad toed in.
