Old 08-16-2005, 11:05 AM   #1
n240sx
n240sx is an unknown quantity at this point
loss of brake pressure
I changed my rear brake pads yesterday, bled the brakes (because I opened one of the brake lines to try and relieve pressure on a stubborn piston), took the car for a test drive and everything checked out ok. Then on the way to work today (which is about a 30-40 mile drive), when i was about a mile from my building, my brake pedal decides to lose all pressure and drops to the floor. The car did come to a stop though. Anyway, when I pulled into my parking lot, I could smell brake fluid, but when i checked to see if i lost any fluid. I didn't. Now the brakes have more pressure, but they are still fairly soft. So, i'm now sitting at work, hoping to make it home so i can try to resolve the issue.
The only thing two things that i can think of that could have caused problem are A.) didn't bleed the brakes enough or B.) when i pushed the passenger side piston into the caliper, a small section of the piston dust boot came over the top of the piston, and i left it that way. I didn't think much of it, but could this have been the problem? Any help would be appreciated.
n240sx is offline   Reply With Quote
Old 08-16-2005, 11:13 AM   #2
aznpoopy
aznpoopy's Avatar
wait.
the piston rubber dust boot came over the top of the piston?
is it getting pinched between the piston and the brake pad?
that is bad dude.
edit:
oh yah. pedal to the floor = bad m/c *or* leak in the hydraulic system. since you smelled fluid, its probably a leak. so start lookin. you wont see a slow fluid loss in the m/c because it takes alot of time for the air (coming in at the source of the leak) to travel all the way up there.
Old 08-16-2005, 08:59 PM   #3
gechalx
gechalx is an unknown quantity at this point
Send a message via AIM to gechalx
i have the exact same problem i've replaced my brake pads twice so far.. so i did some further inspection and it seems like i'm leakin brake fluid from my calipers... so now i'm going to need to buy a new set of calipers..
gechalx is offline   Reply With Quote
Old 11-01-2005, 11:24 PM   #4
carkid0007
carkid0007 can only hope to improve
Alright well I have this problem, Pedal goes to the floor, and I just replaced the Master Cylinder and bled the brakes and still puzzled because it didn't fix the problem...Any ideas ?, What to check and what not ?
carkid0007 is offline   Reply With Quote
Old 11-02-2005, 01:27 AM   #5
Supreme
Supreme's Avatar
Supreme is an unknown quantity at this point
Send a message via AIM to Supreme
Had the same problem today. Did them yesterday, bled them twice and today lost pressure. When I checked, all my brake fluid was gone but I found no puddles. Surely enough it was leaking through one of the brake line connections that my friend left a bit loose. Problem solved after tightening it and bleeding it one more time.
Signature Exceeds Forum Limits
Supreme is offline   Reply With Quote
Old 11-02-2005, 08:54 AM   #6
carkid0007
Any suggestions for getting these damn bleeders off they are so old they just wont budge....
Old 11-02-2005, 11:01 AM   #7
OptionZero
OptionZero's Avatar
Breaker bar...?
Replace them with speed bleeders while you're at it, save yourself a ton of trouble next time you bleed brakes.
Check all the bleeder screws and line connections for leakage as well.
Old 11-02-2005, 12:23 PM   #8
Supreme
Supreme's Avatar
I broke one and couldnt remove 2 when I did mine also, too much force will surely snap it off leaving you with having to get new ones.
