Old 02-26-2002, 06:13 PM   #1
maddindian
maddindian is an unknown quantity at this point
Send a message via ICQ to maddindian
Ok I have two questions to ask regarding 5-spd S14, I want to know if what I'm experiencing is normal or not.
1) When I'm in a high gear and the speed becomes to low, I hear a rattling sound coming from the rear (sounds like its coming from the differential), is that normal? It goes away once the RPMs are above 1.5k RPM but its there in any gear when the tach is reading less than 1.5K...is that normal for a 5-spd manual tranny car?
2) When I start the car in the cold, I have problems getting into 2nd gear. I have to fight it to put it in to 2nd and I hear a crunching sound that can't possibly be good. However once the car is warmed up, its as smooth as butter. Is this normal for everyone else as well?
Thanks for your time.
maddindian is offline
Old 02-26-2002, 07:02 PM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
It shouldn't be too hard to put it into second. Do you have a short-throw shifter? My boyfriend's S14 is sometimes hard to put into second if it's cold, but there are no crunching noises. He has the B&M shifter, which makes for harder insertion into gears.
I don't know of a crunching noise at certain RPMs either. My boyfriend is also experiencing some whining noises coming from the rear of the car when slowing down in second. I'll get him to look at this topic when I get home tonight. I'm sorry I'm not of much more help.
S13Grl is offline
Old 02-26-2002, 08:46 PM   #3
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
well when my car is cold, its harder to get into second gear and will *crunch* sometimes. But I just double clutch for the first 2 blocks and then its fine, slides right into gear.
BadMoJo is offline
Old 02-26-2002, 10:38 PM   #4
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
Same here.  When my car is cold, it is tougher to shift into 2nd.  I get kind of a "clunk" but it smooths out perfectly on the 3rd or 4th time I go into 2nd.  I do also hear a slight "vibration" while slowing down while still in gear.  My cause is the wonderful exhaust heat shields--discovered by a Nissan technician.  I couldn't figure out if it was coming from the very front (engine) or the very back (differential), but it is actually my heat shields (sound echoing through the pipes).  I don't think there's anything wrong with either of the questions asked, especially since everybody seems to be having the same concerns, with no diagnosable problems--just odd little quirks of our cars slightly aging.
96SEChick is offline
Old 02-26-2002, 11:10 PM   #5
misnomer
misnomer's Avatar
Transmission fluid is more viscous, that's why it's so tough to put in gear when it's cold.  As far as the rattling goes, it's prevalent on any car when the engine is under heavy strain and being lugged (engine doesn't have enough power to turn the crank properly). Try to avoid it, not good, particularly for your bearings.
And welcome back SEChick!!! :-)
misnomer is offline
Old 02-26-2002, 11:17 PM   #6
tnord
tnord's Avatar
tnord is an unknown quantity at this point
you should never be below 2000rpm much less 1500 in a manual. except for maybe 1st gear.  that bad noise you're car makes when it's that low in the revs is you're drivetrain begging you to downshift, or at least put it in neutral.
tnord is offline
Old 02-26-2002, 11:53 PM   #7
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
Im not sure about rattling, but my 240 definately didnt did make some wierd noises when running at low RPMs, especially if I was in to high a gear going up a hill and the engine got bogged down.
gfisch is offline
Old 02-27-2002, 08:25 AM   #8
maddindian
I thought it was ok to keep the RPMs below 2k but above 1.5K?? I usually hover at around 1.7K during normal cruising and there are no vibration noises.
any comments?
Old 02-27-2002, 10:48 PM   #9
DrDubbleB
DrDubbleB is an unknown quantity at this point
Well...I personally don't like to have the RPMs that low, and it would seem that the engine really doesn't either. &nbsp;It shouldn't vibrate unless you are getting down below 1.5K though. &nbsp;Why are the RPMs that low anyways, are you trying to conserve gas that much?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> &nbsp;It won't kill ya to have them a little above 2K.
DrDubbleB is offline
Old 04-18-2005, 09:59 PM   #10
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
For some reason its still hard for me to get into 2nd when car is warmed up. Any suggestions?
DoriftoPnoy is offline
Old 04-18-2005, 10:40 PM   #11
aznpoopy
aznpoopy's Avatar
thread is from 2002. searching (which you did) = good. bumping 3 year old threads = bad.
try double clutching it. if it works easy with a double clutch, your 2nd gear synchro is shot.
you might want to try replacing your manual tranny fluid.
aznpoopy is offline
