Old 09-19-2005, 01:48 PM   #1
SittinOnDubsWGW
SittinOnDubsWGW is an unknown quantity at this point
Send a message via AIM to SittinOnDubsWGW
overheating problem KA
Ok, well, at first I figured it was probably just the thermastat sticking, nope, still does it. The car overheats and sits pretty high up on the temp. gauge, most of the time though if I'm able to get out on the highway or able to get up to a decent speed the temp will drop back down.
All fluids are fine, fan is working fine as well, could it be the radiator?
Bye Bye S13
98 S14 Stock at the moment.
SittinOnDubsWGW is offline   Reply With Quote
Old 09-19-2005, 01:53 PM   #2
student_drifter
student_drifter is an unknown quantity at this point
try flush your cooling system and replace all the fluids with new coolant/water... if everything cleans out and your car is still over heating i would look into the Fan clutch which seems to be a pretty common problem on sohcs but i see you have a dohc with the same symptoms... just something to look into
student_drifter is offline   Reply With Quote
Old 09-19-2005, 04:24 PM   #3
aznpoopy
aznpoopy's Avatar
bleed flush is always a good idea. but based on the above it definitely seems like a problem with your fan.
Old 09-19-2005, 04:39 PM   #4
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
sounds like u got debris or some rust somewhere up in the radiator blocking the flow. it could also be your fan like was said about. is it a stock clutch fan?? is the shroud on ? tell us more
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 09-19-2005, 05:23 PM   #5
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Jack up the front end of the car, uncap the burp hole on the top hose housing, fill the rad until fluid comes out of the burp hole, fill the reservoir, recap the rad, then run until normal operating temp. Also, check to make sure that the water pump is not leaking from the bottom hole...if it is, then replace the water pump.
After the car is driven for a little while (or the A/C has managed to set the thermostat to open), the lower rad hose should be hot. If not, then there is clogging or a bad thermostat.
zero.counter is offline   Reply With Quote
