Old 09-22-2005, 05:35 PM   #1
blackdoutrsx
blackdoutrsx is an unknown quantity at this point
KA engine randomly dieing...
i have a 92 240sx se and it will randomly die while idleing or driving and wont start back until like an hour. ive already done the following:
Change fuel filter
New Distrubutor
New Rotor
New Sparkplug wires (NGK)
New Sparkplugs (NGK)
cleaned MAF,
regrounded MAF to somewhere else besides stock location
Cleaned throttle body
Checked Grounds and cleaned
Checked Vaccum Lines
checked Fuses
Recently used injector cleaner about 2 months ago
changed the wire harness
changed the fuel pump relay
changed the coolant temp sensor
and it still dies on me ...has anyone had this happen to them or have any other ideas on what could be wrong ? oh yah also the ecu reads 55 so its fine
thanks daniel
blackdoutrsx is offline   Reply With Quote
Old 09-22-2005, 06:02 PM   #2
s134
s134 is a well-known jackass
replace the maf
s134 is offline   Reply With Quote
Old 09-22-2005, 10:08 PM   #3
Toka Motorsports
Toka Motorsports's Avatar
Toka Motorsports is a well-known jackass
youve probably got a vac. leak, you may want to look at your vac. hoses for cracks... i had a problem where my car would randomly die at stop lights etc. i looked around and found a cracked vac. hose before my throttle body. i taped it up with electrical tape and haven't had my ka die since..
Toka Motorsports is offline   Reply With Quote
Old 09-23-2005, 12:16 AM   #4
Jdotsturn
Jdotsturn's Avatar
Jdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond repute
Send a message via AIM to Jdotsturn
yea id say check the hoses too !
Jdotsturn is offline   Reply With Quote
