Old 09-23-2005, 12:23 AM   #1
A17Z
A17Z is an unknown quantity at this point
s14 rear end sounds and vibartions, differential?
I'm getting a loud, roaring rear end sound and vibrations especially around 55mph. At first I thought it was my tires were going bad. I tried a couple of sets and the sound was still there. So I thought it was one of my wheel bearings so I replaced one of them. Sound still there. Then I rememered I changed my diff fluid with 85w-140 gear oil (really thick stuff). I'm thinking that has something to do with it. I'm going to switch it out with 80w-90 but any does anything think that would be the problem? Previous owner of my car installed a vlsd (i think it's a vlsd and i'm assuming the internals weren't swapped out for an aftermarket lsd).
A17Z is offline   Reply With Quote
Old 09-23-2005, 01:30 AM   #2
sw20>>s14
sw20>>s14's Avatar
driveshaft?...worth checking out...
sw20>>s14 is offline   Reply With Quote
Old 09-23-2005, 01:39 AM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
driveshaft, maybe the diff isn't bolted on tight on the casing end?
SochBAT is offline   Reply With Quote
