Old 09-21-2005, 01:45 PM   #1
Neo Yakra
Neo Yakra's Avatar
Neo Yakra is an unknown quantity at this point
Double Layer Tiiming Chain
I know alot of performance engines use doulbe decker timing chains...im buying add-ons for my sr20 and i was wondering if anyone knew of any aftermarket companies that offered these?? or is it a bad idea?? is it possible!!
If you Die.... you Die
"Bruce Lang"
3 Time National Judo Champion
Neo Yakra is offline   Reply With Quote
Old 09-21-2005, 01:59 PM   #2
PROJECTRB240SX
PROJECTRB240SX is an unknown quantity at this point
Why? The Sr's Have Tensioners So There Is No Need For The Added Weight And Width Of The Chain.... You'd Be Better Off Converting To Belt Drive If You Were Looking To Upgrading Your Timing Set.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY!
PROJECTRB240SX is offline   Reply With Quote
Old 09-21-2005, 02:48 PM   #3
S14DB
AFC #1
S14DB's Avatar
It isn't a high drag pushrod engine with insane springs to take care of slack. OHC engines don't have a lot of drag and aren't going to put that much load on the chain.
Old 09-25-2005, 11:27 PM   #4
Neo Yakra
Neo Yakra's Avatar
Thanks...thats what i thought....
"Bruce Lang"
